Help needed with 91 SE
Old Aug 14, 2010 | 10:30 AM
91WBSE's Avatar
How's it goin everyone?
I have a problem with my 91 SE. The other day it started running horrible after restarting it at operating temp. It runs fine the first time you start it. After you shut it off and restart it a little while later, it can barely idle. It chugs and tries to stay running. The tach jumps up and down while its doing this(at any rpm). When you try to rev it, it struggles to gain rpm. After letting it sit overnight, it'll run fine in the morning. Any ideas where to start looking? Could the distributor cause this? Here's a video of it trying to idle.
http://www.youtube.com/watch?v=XtFcFHOCJX0
Old Aug 14, 2010 | 12:12 PM
YearOfTheGus's Avatar
fuel injectors?
also check the distributor cap and rotor for cracks or wear.
Old Aug 15, 2010 | 12:02 AM
91WBSE's Avatar
Wondering where to start troubleshooting. Would a vacuum leak somewhere cause this? But why does it start and run so great when cold?
Old Aug 15, 2010 | 07:14 AM
maxinout93's Avatar
I used to have a similar problem. the car would run and start great when cold or just starting in the morning, then once it warms up, it barely wants to crank and run, then it runs with a putt putt. Turned out to be a bad fuel injector. I had mechanics tell me all kinds of things like a burned valve, I needed a new engine, all types of things. Good thing I didnt listen to them!
Old Aug 15, 2010 | 10:41 AM
91WBSE's Avatar
As far as fuel injectors...I've had a faulty one in the past and I'm almost positive this isn't the problem here. I was able to drive it this morning. I floored it and could feel surging/cutting out as it revved thru first gear. As it did this the tach needle would fall a couple rpms. When I came to a stop the same thing would be happening. Every couple seconds it cuts out(for a split second) and tach needle drops.
Old Aug 15, 2010 | 11:15 AM
Augustus Maximus's Avatar
Well what's is it ?
Old Aug 23, 2010 | 01:37 PM
91WBSE's Avatar
So it turns out the distributor was bad. The shaft was very sloppy and I'm assuming the module/sensor inside was bad. It would run great while cold, and hesitate, skip, cut out, idle rough, etc when warmed up I haven't felt the engine this smooth in a long time. Oh btw the car has 297,400 miles. Runs like it has less than half that now. Thanks to those who gave their input.
Old Aug 24, 2010 | 10:14 PM
myvg30's Avatar
ya mine was the crank pos sensor in the dizzy
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MikesChevelle
Aug 9, 2015 11:50 AM
