Engine bay connectors/plugs - where to get?
Old Oct 2, 2010 | 07:41 AM
Maximan190's Avatar
So before I go and buy a motor, Im looking to replace a few connectors on the engine bay harness - im leaving nothing to chance, i want this thing to run 110% when finished. I went through and cleaned inside all the plugs/connectors and i found a few with either a cracked housing or dried out/cracked wire sheathing. These are at least the ones id like to replace:
-Fuel Injector plug @ cyl #2
-Coolant temp sensor plug (red plug)
-Coil pack plugs @ cyl #1 #2 #4
Aside from hoping there are good condition plugs to be found at a junk yard, and i could check the dealer i suppose ($$), i just wanted to see if there are any good sources out there to find these pigtail connectors that i can splice/solder in..? I could also see how good these plugs are on the JDM motor when i get it, since the harness stays with the motor when they pull it
generic picture from one of the warehouses i plan to scope out:
http://www.jdmenginezone.com/pics.ph...m/DSC01698.JPG
I did come across this, looks like a specialty site for Z parts:
http://amszstore.com/main/product_in...roducts_id=118
^ and that looks like the same as our injector plugs, id go ahead and buy 3 of those for the front and then the entire subharness for the rear 3 injectors, then all 6 injectors will have new plugs
Old Oct 2, 2010 | 07:53 AM
shiloh51933's Avatar
That motor looks great, twin cam...niiice!!! If you have to go the dealer but I believe Aids Auto sells good injector plugs, there cheaper than going to the dealer.
James92SE
142
Jan 2, 2024 09:23 AM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
