Stutter upon acceleration...help please
Old Sep 13, 2010 | 04:32 PM
Cdg2125's Avatar
My buddy has a 3rd gen max and he's telling me he's got stuttering when he accelerates. Plugs and wires have been changed and he says that the stutter is a little worse. Had some oil on the plugs so I figure his valve gasket is shot. But that wouldn't cause stutter. Was thinking possibly O2 but he has no CEL. I was hoping someone may have a solution or specific direction I should have him check. I appreciate the help.
Old Sep 13, 2010 | 05:57 PM
BenStoked's Avatar
Jesus was a Zombie.
likely it's injectors.
Old Sep 13, 2010 | 06:23 PM
shiloh51933's Avatar
What has he looked at so far? Check ECU 4 any fault codes yet, a good place 2 start.
Old Oct 1, 2010 | 11:24 PM
elusivemax93's Avatar
Is it a vg30e or a ve30de? Taking it from the word wires it's vg30e. Check maf distributor timing and the rpm signal wire. Fuel filter. The list goes on first look at those
Old Oct 1, 2010 | 11:32 PM
maxinout93's Avatar
Check your injectors to see if any are bad.
Old Oct 2, 2010 | 06:11 PM
Maxtastic GXE's Avatar
I just went through this, after checking the fuel,pressure,did a full tune up and it would bog,mis-fire(especially under hard acceleration) i found up it was the sesnor in the distributor so I got a used dist n it was running like new again. also I checked the ignition module and it was good as well.
Rage Maximus
Sep 3, 2015 12:26 PM
FiSH
Apr 18, 2003 10:22 AM
92pearl
Apr 9, 2003 08:35 PM
Aphrodisiac
Mar 3, 2003 10:02 PM
Maximan190
Jan 14, 2003 07:53 AM
