EZ spoiler hole fix
Old Oct 22, 2010 | 04:55 AM
Hectic's Avatar
EZ spoiler hole fix
This place is deader than a zombie baby on Halloween. My car isn't finished so until then I have nothing to share other than simple **** like this. It took me 45 minutes looking for a suitable metal when I happened to see a bottle cap on the floor. Problem solved! Simple and easy, plus you get a nice buzz getting the parts I used a $.99 two part epoxy and held them down with a couple bricks.
Old Oct 22, 2010 | 05:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
i wouldn't say that ideal...but if it works for you then go for it!
Old Oct 22, 2010 | 06:04 AM
Augustus Maximus's Avatar
Hope you're gonna put the spoiler on that ****. I would loathe to know that's what the 3rd gen has gone to .
Old Oct 22, 2010 | 09:34 AM
Matt93SE's Avatar
STFU n00b!
Damn that's ghetto...
at least you could have painted the caps with some body color spray paint and glued them on from the bottom. clean and remove all the old sticky crap off the trunklid while you're at it.
Old Oct 22, 2010 | 03:59 PM
Hectic's Avatar
Oh jeeze.. The goal is to keep rain out so I can go ahead and install certain things in the trunk which are susceptible to moisture. Obviously I reinstalled the spoiler. Temporarily, as I have an aftermarket one I need to do some work on and paint before permanently installing it.
BTW Matt, I would have sealed the the holes from underneath, if it weren't for the fact that you cant get at them from underneath Which is why I needed a metal that was thin but strong, in order to make it as flush as possible.
Old Oct 22, 2010 | 05:12 PM
spiers's Avatar
Damn thats ghetto...whatever works though
Old Oct 22, 2010 | 06:53 PM
Hectic's Avatar
Fortunately it doesn't matter how it looks, I thought I cleared that up.. The goal is to STOP LEAKS, not shave the spoiler, prep the surface for remounting, or make it look good. Should I have filled the holes with bondo? Cut into the tubular steel reinforcement of the trunk lid to gain access underneath the holes? Nah, it's called smash 4 bottle caps, glue them over the holes, reinstall the rotting and rusting stock spoiler until the new spoiler is ready. Meanwhile my trunk doesn't leak anymore, so I am free to move on with more important matters.
Old Oct 23, 2010 | 05:45 PM
Gunther's Avatar
Old Oct 24, 2010 | 05:00 PM
Matt93SE's Avatar
STFU n00b!
meh. it's still ghetto.
better way would have been to use a hole saw and drill through the trunk support under these spots, then glue from the bottom. :P
Old Oct 24, 2010 | 06:17 PM
Hectic's Avatar
ok Matt. That would serve absolutely zero purpose aside from making the job harder. If it needed to be pretty (no spoiler), i'd go buy a GXE trunk lid.
Old Oct 25, 2010 | 05:04 AM
http://www.biosafe-inc.com/ag_adhesives.htm
Swapping the spoiler from the donor to the shell and I'm using this here glue. Been using it for years gluing the big capacitors to the chassis of my audio power amp designs. It should provide a water tight seal me thinks, thus circumventing the need for "the Hectic solution" .
Old Oct 25, 2010 | 05:58 PM
Hectic's Avatar
Yeah that stuff costs $5. I spent $5 as well, but 80% of my $5 went towards 4 alcoholic beverages.
Old Oct 26, 2010 | 01:34 PM
Got it done today.
Fbana41
Aug 29, 2016 12:18 PM
leatherneck
Sep 30, 2015 09:16 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
