Sudden rough idle + sulfur smell?
Old Nov 28, 2010 | 03:02 PM
gladiator's Avatar
Ever since the weather got a little cooler in NYC, my Max has been idling really rough. At higher RPM, anything above 1000 its fine but at regular idle 600 its really really rough.
I also noticed a strong rotten egg smell at the exhaust too.
I just tuned up the car this summer, is the injectors going or something?
Old Nov 28, 2010 | 03:10 PM
akurtzer57's Avatar
Catalytic converter is shot.
Old Nov 28, 2010 | 03:23 PM
gladiator's Avatar
wow thanks for the quick reply, so the cat is also the culprit of the rough idling?
Old Nov 28, 2010 | 03:34 PM
Stormzusmc's Avatar
could be if its clogged
Old Nov 28, 2010 | 03:43 PM
coolsun's Avatar
seafoam it. It reduced my nox alot when i didnt pass inspection, which shows it works.
Old Nov 28, 2010 | 03:55 PM
gladiator's Avatar
I seafoamed once this summer through the brake booster. Then change plugs, wires, cap, rotor and fuel filter. Then ran a bottle of Redline fuel injector cleaner.
I still have one more bottle of seafoam, thinking of putting in the fuel tank little by little.
Old Nov 28, 2010 | 04:10 PM
gladiator's Avatar
also, do our cars have one or two cats?
Old Nov 28, 2010 | 05:04 PM
jbbons25's Avatar
Just one cat.
And I don't think Seafoam will help a bad cat anymore.
Old Nov 29, 2010 | 05:34 AM
gladiator's Avatar
how easy would it to buy one of these and install it myself?
is direct bolt on really direct fit?
Old Nov 29, 2010 | 05:38 AM
Stormzusmc's Avatar
yes its easy as long as the bolts are rusted to hell....otherwise youll have to heat them up with a torch a few times
Old Nov 29, 2010 | 05:19 PM
coolsun's Avatar
mines were rusted onto the Y pipe, heat wasn't even an option, but i did order my Y-pip with the cat and changed both out at the same time. There is also a $50 rebate for the cat after you send your old one back.
Old Nov 29, 2010 | 06:00 PM
Matt93SE's Avatar
STFU n00b!
just snap the old bolts off and through-bolt the new cat with some 3/8" stainless bolts from the hardware store. they'll last forever that way.
If the heads are ruined on the old nuts/bolts and you can't get them off, use a disc grinder or hacksaw and just cut 'em off.
but yeah, it's most likely a failing cat that's causing the problems. only way to check is to remove the cat. since it's 20 years old, it's likely dead/dying. might as well have the new parts ready to install when you tear it apart.
replacement cat $100
couple flange gaskets (buy the Nissan ones. parts store gaskets are crap. nissan are more $$, but they're good stuff.) $15
four 3/8" x 1.5" stainless bolts $10
four 3/8" stainless nuts $1
8 3/8" flat washers $0.50
4 3/8" lock washers $0.50
anti sieze $3
done.
tarun900
19
Dec 20, 2021 06:57 PM
chisam14
Nov 6, 2018 08:56 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
