factory freak idle..??
Old Jan 6, 2011 | 06:39 PM
BklynsmoeVE's Avatar
Hey how's it going guys I'm pretty new to the org this is my first thread so bare with me if its a lil unorganized I appreciate the patience and aid in advance..
So..here's what I've done..cleaned throttle body replaced gasket too,clean iacv and replaced gasket too,changed valve cover gasket,seafoamed my car,have always done regular oil changes and maintenance(filters,pumps..etc).
Now here's the problem my cars always had a nasty idle but at one point a few months ago after doing all this(tb,iacv,vcg,seafoam..etc..) my cars idle seemed pretty fine for the most part but now its back to crappyness again..when I pull up to stop signs/red lights nd throw it in neutral while coming to a stop my idle drops to 500 even 400 sometimes then goes fluxuates between 5-750 rpm. While standing still it sometimes does the same thing jus fluxuates rpms nd I get a nasty vibration while its idleing.
My question now..from my knowledge and what I've read from the org I've came to a few conclusions first off I read it cld be my ecu coolant temp sensor or a throttle position sensor mayb one or both went bad..second I was thinking maybe there's a vacuum leak somewhere was thinking of maybe doing a smoke test? Lastly the most common of problems could it just be my rusted exhuast manifold studs? My cars got 180k on the highway it runs like a charm but I'm thinking the rust finally caught up...btw it doesn't feel like I'm at a loss of power when I put it to the metal I feel like its pretty much all there so idk what else to conclude but I'm in possession of a factory freak lol
P.s I'm kind of a newb so I would RLY appreciate it if you guys could be a little bit more detailed in your responses again thanks again in advance your advice and opinions are welcome!
Old Jan 6, 2011 | 06:43 PM
Sry forget to mention that when placing my hand behind the muffler I feel a nasty put put feeling..like its not a continous flow its all disrupted nd weird
Old Jan 6, 2011 | 06:47 PM
VEvolution's Avatar
I miss my VE
To sum it all up, the car idles like crap, but accelerates masterfully..
Old Jan 6, 2011 | 11:56 PM
maximo018's Avatar
Those are also signs of a bad injector. Whats ur gas mileage like? Vacuum leak u spray brake cleaner and see if change in rpms.
Old Jan 7, 2011 | 06:30 AM
chrome91's Avatar
yeah definitely test your injectors
Old Jan 7, 2011 | 09:41 AM
VEvolution's Avatar
I miss my VE
Please tell me how its a sign of bad injectors when he and I mentioned that it accelerates just fine without any powerloss. I even made sure to come in and mention that after his post. I've had bad injectors before on my VG, and it feels similar to a bad coil. No power anywhere on the powerband, and the idle was actually nowhere near as bad as on this guys car. Forget that he mentioned "putt putt".. It doesn't putt putt like a bad injector, trust me. It putts like once every twenty seconds...... And we checked for a vacuum leak with throttle body cleaner. Everything checked out okay. And brake cleaner? Seriously maximo? You go ahead and keep spraying brake cleaner on your rubber vacuum hoses, but don't tell people online to do it, thanks.
Old Jan 7, 2011 | 10:11 AM
James92SE's Avatar
2 VE's are better than one!
A bad injector can very well be fine at WOT. My black VE I got back in the day from flyry had a bad/sticky injector but flew like a bat out of hell at WOT. At idle it would be pretty stumbly occasionally..
Old Jan 7, 2011 | 10:31 AM
VEvolution's Avatar
I miss my VE
Really? Did not know that. But the power isn't just there at WOT. It's also there anywhere except idle. Thats funny that you assumed hes always at WOT though
Old Jan 7, 2011 | 11:02 AM
yeah I get you james but the cars actually pretty fine though when just cruising, its fine low rpm mid rpm all the same pretty much.......in low rpm 2nd gear I get this rly bad kick/studder from the car its feels mechanical like two hard parts knocking together I was assuming its my tranny/motor mounts feels like its coming from right underneath me I highly doubt this has to do with the fuel delivery of the car and just a seperate issue but just thought mayb id mention it just incase but if it is a seperate issue plz disregard lol cuz id like focus on my original post...to clear it up I don't WOT everywhere the cars power seems fine jus ****ty idle thanks again
Old Jan 7, 2011 | 11:23 AM
James92SE's Avatar
Well, I didn't mean to imply that you were always at WOT. I was just talking about WOT in relation to you guys mentioning it accelerates well. The VE I described above also accelerated well. It drove perfect in all aspects. It was just occasionally stumbly at idle. As soon as it had any gas (be it moderate acceleration, WOT, whatever), it was perfectly fine.
The chances of this are likely small, but are you sure this low RPM in 2nd gear problem isn't just a by-product of driving "technique" (for lack of a better word)? From what I gather you're a relative new-comer at driving stick? For instance, if you're going slow, and still shift iinto a higher gear, you'll get this shaky/jerky action going on as it bogs the RPM range down to match the speed. Basically shifting into a higher gear but not having enough speed (think trying to go into 5th at like 20 mph or something).
Old Jan 7, 2011 | 12:23 PM
VEvolution's Avatar
I miss my VE
I really had no idea its possible for injectors to go bad and still have the car accelerate well. Its just not registering because every single car I've seen with bad injectors was really sluggish and had a "putt putt" every second coming out of the tail pipe. To check those rear injectors, the intake manifold has to come off? Highly unlikely its some kind of sensor right? Because I noticed in that 300ZX VE thread, hes having idle issues and 4signs mentioned to check a few sensors.
And as for his manual driving, hes pretty much got the stick down the right way. That retarded jerking in second gear happens to me too. It happens when your cruising in second at the speed you should be at second, lets say behind a car or something, waiting to either decelerate or accelerate, the thing will start to jerk big time unless you open up that throttle a bit. Feels like a mechanical issue in the tranny. But thats a totally different issue.
Old Jan 7, 2011 | 01:10 PM
Oh alright I get what you mean now I thought for a second you think I WOT around town lol but honestly pretty much what VE evolution said is on point my driving skills have been on point for som time now and that shaking..jerkyness kinda feels like a tranny issue or tranny insulator issue I hope ( mayb throwout bearing? )..but yeah we cld rule that drivin technique out..anythin else come to mind?
Old Jan 7, 2011 | 02:28 PM
shiloh51933's Avatar
I'd be looking for good spark, fuel/emissions system, injectors/ wiring harness to start with.
Old Jan 7, 2011 | 02:33 PM
James92SE's Avatar
You don't have to remove the intake manifold to test the rear injectors. There's a harness by the power valve that goes to the rear injectors and you can test each rear injector here with the multimeter
Old Jan 7, 2011 | 05:04 PM
maximo018's Avatar
No there all different as if they had their own personality. Just similar in some ways. I'm with James on the injectors because from experience what bklynnsmoeVE described my car was doing the same thing. And guess what? Bad injector. Tap the gas just to bump the rpms and its runs like a champ. Once it drop down to 500 rpms its sputters and puts and eventually acts as though it wants to die. As for the break cleaner I don't drench anything in it I just shoot a quick mist. Worked for my manifold leak & hasn't harmed anything. I know it removes oils so I follow with aromall(what we use at work). U can use almost any flammable aerosol.
Old Jan 7, 2011 | 05:14 PM
Creedence85's Avatar
That's classic cylinder not firing, so it's fuel, spark, or even a stuck valve. I had a valve adjuster break, and the remains were holding the valve open so the engine ran pretty much like that.
I recently had a bad injector, at idle it did the classic "puff puff" misfire sound from the exhaust and had a rougher than normal idle. Driving below 4000 RPM it was relatively smooth at light throttle, and had some shudder under heavier load. Above 4000 it felt almost normal. Power was reduced below 4000 RPM but not that dramatically.
Just unplug the coil packs one by one until you find a cylinder that doesn't run worse when unplugged. Then you can check resistance on that coil and injector, or swap with a working one to verify.
Old Jan 7, 2011 | 07:17 PM
VEvolution's Avatar
I miss my VE
I'll check them out.. Remind me about the ohms though. Anything below 11 ohms is a bad injector? And I test the injector itself, right?
Even a small mist of that crap turns any type of rubber into hard dry rubber which leads to cracking and worse. Its too harsh to be misting anything rubber or plastic. Just sayin.. Not tryin to be a **** or anything.
Really hope its nothing serious internally. We did just do some Seafoam but not much changed since then. The coil pack check was done as well with no changes, so I'll check the injectors for now and we'll work from there.
Guys what about exhaust manifold studs? His look pretty rusted. Would these be symptoms of broken exhaust studs?
Old Jan 7, 2011 | 07:50 PM
James92SE's Avatar
The FSM says between 10-14 ohms. Most of the ones I check usually ohm at around 10.6-10.9ish. Bad ones the vast majority of the time will give something wayyy off like .899 or something.
You have to test different combinations of pins on the harness to test each injector:
Old Jan 9, 2011 | 03:35 PM
Alright cool thanks a lot james appreciaite it thanks to everyone else too for feedback..me and ve are gonna try and check em out this week hope its that and nothing more
Old Jan 9, 2011 | 07:47 PM
VEvolution's Avatar
I miss my VE
You better hope it aint the rear ones! Your removing that IM, not me
Old Jan 10, 2011 | 04:26 PM
somewhere out there brudda bob is watching us all..
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
