Will VQ30DE injectors from a 95 work?
Old Jan 24, 2011 | 03:13 PM
txsilverado1's Avatar
I have an opportunity to get a full set of injectors from a 95. Will that do any good for my 94 VG30?
Old Jan 24, 2011 | 06:05 PM
akurtzer57's Avatar
No they will not. 89-91 vg30 pinkish color 180cc square plug. 92+ vg30e same as 89-91 except they have the oval type plug. The VE and VQ use redtop 259cc injectors. If you are needing a set I happen to have a good set off vg30e injectors with oval type plug.
Old Jan 25, 2011 | 12:40 PM
PM Sent
Old Jan 25, 2011 | 07:26 PM
maximo018's Avatar
Actually they will work but you have to swap over the fuel rail also from either a VE or VQ. Can't remember about the connectors but they should be fine.
Old Jan 25, 2011 | 08:15 PM
akurtzer57's Avatar
rails are same connectors and cc size is whats different.
Old Feb 2, 2011 | 09:12 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
incorrect. all 3 types of rails are engine-specific and won't fit on either of the other 2 engines.
if you mean that the rails for his car are the same as what he needs to run VQ injectors, then yes. but early-style square-connector injectors' rails are totally incompatible with oval-connector injectors and vice-versa b/c the o-rings are in different locations and are different sizes. not an issue for OP, but maybe an issue for other people that see this thread with 89-92's.
no offense maximo018... BUT, I actually installed 4th gen injectors on my '90 VG and experimented with what fits and what doesn't so here's the whole truth and nothing but the truth: yes and no.
why no?
I had some 4th gen injectors in my car (90 gxe) BUT they flow too much fuel so the car ran very rich. they are 259cc (ve and 4th gen) vs 180cc (vg). without nistune you're going to eventually cause serious engine damage due to oil washdown. and yes i learned that the hard way.
why yes?
on a VG 3rd gen, the fuel rails and injector clips both have to match the 'style' of injector you are using. old style injectors were 89-92 and new style was 94, with 93 switching partway through. all VE and 4th gen use the "new style" injector, hence why they will fit in 93.5+ VG rails. so since you have a 94, only thing you'd need is the injectors themselves, whereas i had to acquire said fuel rail for my '90. ve rails and 4th gen rails only fit on their own respective engines.
so the parts list is:
92-99 VE/VQ30DE injector/o-rings
93.5+ VG fuel rail
93.5+ VG / 92-99 VE/VQ30DE injector harness plugs
http://s164.photobucket.com/albums/u...ver/injectors/
Finkle
Sep 27, 2015 09:53 PM
Ray229Harris
Sep 16, 2015 08:16 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
t6378tp
Aug 24, 2015 07:03 AM
kenc15
Aug 5, 2015 08:29 AM
