Questions about my vq35 Max
Old Mar 7, 2011 | 11:34 PM
ramanx806's Avatar
Hey guys i have 93 maxima with a 3.5 swap.
Im having 2 problems.One is my cluster doesnt go past
35mph.[could it be the speed sensor on the tranny or is it the cluster]
Second question my clutch engages very high [almost close to resting position,could it be adjusted?] Thanks in advance
And is there anyone one on here with a vq35 swap in a 3rd gen?
Old Mar 8, 2011 | 04:58 AM
Augustus Maximus's Avatar
http://forums.maxima.org/all-motor/5...ss-thread.html
Here's a properly done 3.5 swap in a 3rd gen...show us pics.
Old Mar 8, 2011 | 10:32 AM
akurtzer57's Avatar
I want some pics
Old Mar 8, 2011 | 12:02 PM
ramanx806's Avatar
here is the pic and now can some one help me?
Old Mar 8, 2011 | 12:12 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
damn wedged pretty good!
Old Mar 8, 2011 | 12:14 PM
ramanx806's Avatar
actuali theres alot of room but the wiring is a mess
Old Mar 8, 2011 | 12:28 PM
Matt93SE's Avatar
STFU n00b!
No ideas on the cluster. I would think it's in the cluster though since it just receives a signal from the tranny regarding speed and spits it out. if it was inside the tranny, then it would either work or it wouldn't.. not stop at 35mph.
does the car actually go past 35mph though? that would be another issue altogether.
As for the clutch, try bleeding the clutch system. if that doesn't work, adjust the rod on the back of the clutch pedal that pushes on the master cylinder. you can adjust that a bit and it should move the engagement height up or down.
Old Mar 8, 2011 | 12:45 PM
James92SE's Avatar
2 VE's are better than one!
This looks like the VQ35 swapped Max from NY from a couple years back. Is that you, or did you buy it from that guy?
Also, I assume you're running the stock VE tranny?
Old Mar 8, 2011 | 03:23 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
if your using the 3.5 cluster there is some kinda adjustment screw on the back of it tht i heard.
Old Mar 8, 2011 | 07:40 PM
CMax03's Avatar
Pm Aaron, he'll be best to answer that......since he was so far ahead of the curve.....
MaxLife17
Jun 27, 2019 01:37 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
