Rear Speaker Problem
Old Apr 19, 2011 | 07:10 PM
road_warrior05's Avatar
The problem with them is......they don't work. When I first got the car almost two years ago, the rear speakers would sometimes cut out. After about two months they quit working for good. I always thought they were just bad speakers, but when I replaced them last night, they still wont work at all. The wiring connections at the speakers and at the radio are fine. I'd really like any help before I try to replace the wires all together
Old Apr 19, 2011 | 09:47 PM
Maxkiller's Avatar
Radio is shot or wires are shot. Hook up wires to a good known radio or use a multimeter with really long leads to check continuity. Although if the old ones were cutting out my money is on the radios internals.
Old Apr 20, 2011 | 07:08 AM
Well its got to be in the wires because I replaced the radio not too long ago
Old Apr 20, 2011 | 08:59 AM
Chris Gregg's Avatar
Get Off My Lawn
Well, go work on it and let us know. Pretty easy to track this issue down.
Old Apr 20, 2011 | 10:21 AM
dash8guru's Avatar
Lol, my stock stereo is the same... rear speakers cut out and it has no channel/function display.
Old Apr 20, 2011 | 10:27 AM
I'll see if I can do some more work on it tonight after work, if it's not raining
Old Apr 20, 2011 | 12:47 PM
jbbons25's Avatar
Bose/non-Bose? Bypassed the amp(s)? If not, maybe the stock amp(s) are shot.
Old Apr 20, 2011 | 02:25 PM
DennisMik's Avatar
Your head unit definitely has a problem, could very possibly be the cause of the speakers cutting out. It would be nice if you were to tell us what kind of radio you have.
Old Apr 20, 2011 | 04:11 PM
When I got the car, it had an older sony head unit with pioneer speakers in the doors and rear.
Old Apr 20, 2011 | 05:37 PM
Cliff Clavin's Avatar
Way out West
Seems pretty obvious. HU problem or connection problem somewhere along the line. The factory wiring is really thin and crappy.
If you have the time, you can take out your interior and rewire the entire car and have it done right with quality wire and good connections and grounds.
Wire isn't that expensive, but it will take you some time. You can also pull up the carpet and add dynamat or some other insulation or take out OEM insulation if you want to lighten your car. It is also a good way to learn how to disassemble and reassemble your interior if you want to fix, change or replace anything else.
Old Apr 20, 2011 | 08:14 PM
I was strongly considering doin that this weekend since I want to redo the wiring for my sub box in the trunk
Old Apr 20, 2011 | 11:49 PM
fattamax's Avatar
First thing you should do is bypass the amps if you have them. Then take a test speaker (known to be good) and test the wiring directly. I highly doubt the wires just went bad. I have worked at a stereo shop for the last 15yrs and yes it could be all of the above mentioned but check the easiest first. Head unit, then bypass amps, wiring from front to rear, and whatever speakers are installed. If you have the bose system it is best to dump all of that and start over. (No Highs and all Lows, must be BLOWS) IMO Check the easy stuff and the problem will norally reveal itself.
Old Apr 21, 2011 | 07:07 AM
My car had the standard stereo, not bose.
Matt93SE
May 24, 2019 02:58 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Mcnabb34
Aug 11, 2015 08:45 PM
