Weird clunking sound when braking (axle problem?)
Old Apr 28, 2011 | 08:59 AM
gladiator's Avatar
This problem was better before, if I brake hard there would be a clunking sound. Or if the car was carrying a lot of things, every time I brake something would clunk like two metal bars hitting.
Now the problem has gotten worse, the clunking sound happens every time I brake. My friend said it might be the axle, although I can't imagine what could be wrong with the axle to warrant such a symptom.
Old Apr 28, 2011 | 02:38 PM
Laevateinn's Avatar
Does it clunk in a certain speed or as in every time you hit the brakes? Check the calipers. The pads may be loose which creates a gap to allow the pads to move in such directions, ergo, hitting the calipers. If you have the time, check the other wheels as well
Old Apr 28, 2011 | 03:59 PM
gladiator's Avatar
Hmm. something is definitely loose. Its at any speeds, but its worse when I park. Like if the wheel is turned far left or right, theres a major clunk sound. I can't replicate it each time but it happens when I brake hard.
Old Apr 28, 2011 | 04:23 PM
Maxkiller's Avatar
Sounds like wheel bearing or really rooted cv's. Does it squeal or grind or clatter at all?
Old Apr 28, 2011 | 05:30 PM
gladiator's Avatar
no squealing or grinds. CV's were changed in 06
Old Apr 28, 2011 | 10:11 PM
Laevateinn's Avatar
Yeah, I'm almost positive that it has something to do with your pads or calipers.
Old Apr 29, 2011 | 08:24 AM
Maxkiller's Avatar
Come to think of it I had a weird clunk similar to what your describing in the rear brakes of my first maxima, a fully optioned 92 gxe I think. Mechanic told me it was something to do with the 'clips' and since it only did it in reverse at low speed I never bothered to investigate it any further.
Lakersallday24
Nov 7, 2024 07:31 PM
tsi6001
Oct 3, 2022 10:23 PM
vingodine
45
May 21, 2016 12:46 PM
KGMtech
Aug 18, 2015 09:21 AM
Jcof88
Aug 3, 2015 10:43 PM
