Around the engine. . .
I have a new problem. . . I just changed my oil (I use 10w30) and fliter (k&n) replace my old cheap $20 cone air filter with a stock oem replacement K&n air filter. . . now i have strange sounds coming from the engine 1of them is a broke stud and i cant get to it to replace it. so i think im just going to plug that hole with some thermosteel. . .
THERE IS VIDEO but i got pulled over by the cops while doing it lol for doing a 3 point turn before a stop sign. anyhow vid will be posted or linked since i don't know how to post it here. I just want to know what this noise is. . .
Video: http://youtu.be/q0mYVVmCbSs
+1 my coolant temp sensor connection is messed up where to get a new one? here is a pic. the reason my fans are stuck running is here...
i THINK you can just get this then cut and splice it.... i can double check if the plug from the Z will fit on the sensor from the Maxima.
http://www.courtesyparts.com/temp-se...-p-296257.html
Did you have time to look at the video and listen to the car?
there is a stud missing and has broken off on the inside where i cant get to it is there anything else i can do to get it out or plug the hole?
also where can i find the front manifold? everywhere im looking im seeing the rear one.
Junk yard has many cars with decent sensors/wiring, cutting and resplicing will become your new art dealing with this 1989-92 connector sealing bellows that tend to dry rot and expose your wiring.....shoot for upgrading your wiring to the 93-94 VG style connectors cause they're simply more reliable and durable......
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
Dasmith
Sep 23, 2015 08:28 PM
