built ve
Old May 15, 2011 | 06:35 PM
3rdmaxse0's Avatar
built ve
Pics of my Ve with us piston 10.5-1 eagle rods new chains guides tensioners rebuilt vtc and customized inc headers
Old May 15, 2011 | 06:38 PM
3rdmaxse0's Avatar
Je piston obx headers
Old May 15, 2011 | 07:00 PM
Matt93SE's Avatar
STFU n00b!
Nice! Now you just need cams....
Old May 15, 2011 | 07:15 PM
Rods03Max619's Avatar
Looks Nice espeacially with the headers on there....
Old May 15, 2011 | 07:19 PM
dead2fall's Avatar
nice build, i would definitely built the heads, you'll regret it later if u dont
Old May 15, 2011 | 07:26 PM
James92SE's Avatar
2 VE's are better than one!
Wow! Nice! Now what's the deal with the headers? What does customized inc headers mean? Or was that a typo?
Old May 15, 2011 | 07:47 PM
3rdmaxse0's Avatar
Typo the header manifold was bored to match ports its only about 1/4-1/2 " on either side that had to be ground out but kind of cone shape it in to smooth flow and as for bolting up the same forget about it you gotta find your centers which match up vg and Ve lucked out ports centers are same apart but just center the height and side to side then mark and modify holes for exhaust studs as for head work they been cleaned new springs that's about it I get spare heads complete maybe someday ill tinker with them but I'm not going for speed anymore no point just to finish a 8 yr project
Old May 15, 2011 | 07:54 PM
CMax03's Avatar
Those headers are these same ones.....supposibly for a VG huh?
Old May 15, 2011 | 07:55 PM
VQ30MPG's Avatar
Originally Posted by 3rdmaxse0
Typo. The header manifold was bored to match ports; it's only about 1/4-1/2 " on either side that had to be ground out, but kind of cone shape it in to smooth flow. As for bolting up, the same; forget about it you gotta find your centers which match up. VG and VE lucked out; ports centers are same [distance] apart but just center the height and side to side, then mark and modify holes for exhaust studs. As for head work, they've been cleaned; new springs; that's about it. [If] I get spare heads complete, maybe someday I'll tinker with them but I'm not going for speed anymore; no point, just to finish a 8 yr project
For anyone who was having as hard of a time reading that as I was. (Not trying to be a jerk, it was just really hard to read without any punctuation.)
Old May 15, 2011 | 08:00 PM
3rdmaxse0's Avatar
Wow! That was much easier to read. As for the headers, they are indeed for the vg. I found a great deal on eBay and was actually planning on cutting and swapping flanges.
Old May 15, 2011 | 08:05 PM
CMax03's Avatar
You don't like sentences that run forever and without any punctuation that seem to flow forever like a person who never runs out of breath while talking about ever freaking thing under the sun stars moon and sky yeah I know what you're feeling and saying boo
Old May 15, 2011 | 09:20 PM
maximo018's Avatar
Yes! What is up with that. I thought no one made headers for the VE. If they did I would've bought them.
Old May 16, 2011 | 06:29 AM
CMax03's Avatar
Those are OBX VG headers with round exhaust ports not oval...... but check this out they might work on a VE.....
http://forums.maxima.org/5th-generat...r-headers.html
Old May 16, 2011 | 09:04 AM
doubleclutch92's Avatar
VEry nice!!!
Old May 18, 2011 | 09:36 AM
elusivemax93's Avatar
If im not mistaken our ve engines are already 10.5-1 so nothing new with the pistons besides after market. Now the exhaust port work should give him a bit more power and impressive headers granted there vg headers lol. Only issue I see is there not equal length headers so you might end up getting back pressure. I rather spend time and money having custom equal length headers over using non equal lengths. What else you have done besides whats listed here.
Old May 18, 2011 | 01:00 PM
10-1
Old May 18, 2011 | 04:08 PM
Augustus Maximus's Avatar
How's your build going?
Old May 18, 2011 | 04:56 PM
3rdmaxse0's Avatar
Got motor out of basement finishing up mounting mounts accessory bracket fidenza flywheel clutch and bolt on tyranny gonna crank engine outside car first with analog oil pressure gauge first to make sure I make good pressure little paranoid
I got venom injectectors (waste of money)
Asp pulley sleeved
Flywheel
Wsp y-pipe back to magnaflow muffler
75 shot zex never used
Old May 18, 2011 | 05:00 PM
3rdmaxse0's Avatar
Oh and Bosch unobtanium fours spark plugs
Old May 18, 2011 | 08:05 PM
Brad92SE's Avatar
Nice build!! The headers look great. If the engine is still out, I would suggest throwing in ARP rod bolts if you haven't already... they aren't too pricey and would round out a very solid bottom end for whatever you want to throw at it down the road. Do you have any pictures of the pistons?
I dont think many people have had good luck with these plugs... I know my car ran pretty bad with Bosch +4's years ago when I tried using them. Maybe they have improved the design though.
Old May 18, 2011 | 09:36 PM
3rdmaxse0's Avatar
I got pics I posted yrs ago same title I do believe. I was joking with the Bosch I run ngk. I had this car for going on ten yrs on the org maybe 7 or 8 I learned a lot about what works and what doesn't. I have eagle rods and I'm sure there bolts got some tensile strength. Crank lightened zero balanced with rotating assembly. Bunch of stuff I guess, cost me 1400 in machine work and lower assembly
Old May 18, 2011 | 10:50 PM
maximo018's Avatar
I haven't worked on mine that long but have an idea of how you must feel by now. GL.
Old May 19, 2011 | 07:06 AM
road_warrior05's Avatar
[/quote]I dont think many people have had good luck with these plugs... I know my car ran pretty bad with Bosch +4's years ago when I tried using them. Maybe they have improved the design though.[/quote]
Nope, I messed up and bought Bosch plugs about a month ago, and my car runs awful
Old May 19, 2011 | 11:32 AM
only plugs im running are NGK Iridium IX wouldnt waste my money on any other plugs sold at most parts stores if not a ngk brand or denso
Old May 19, 2011 | 01:00 PM
3rdmaxse0's Avatar
Got more pics of short block fresh from shop on this thread. forums.maxima.org/3rd-generation-maxima-1989-1994/597161-ve-finally-machine-shop.html
Old May 19, 2011 | 03:14 PM
This?
Old May 19, 2011 | 05:14 PM
3rdmaxse0's Avatar
Yea that's what I wanted to do thanks
Old May 22, 2011 | 06:21 PM
3rdmaxse0's Avatar
As of this morning engine is bolted in with trans. Before I even touched a wire put oil in and checked oil pressure by crank start. Everything looked good tensioners were tight and lifters didn't squish down at all ( air in lifters would cause that) just need to get some injector insulators because all of mine are cracked or torn. Just hoping for no rain
Old May 22, 2011 | 07:54 PM
nickdoof's Avatar
Nicely done Anxious to see how this thing runs. I'm sure you will have an extremely solid ve. JEALOUS!
Old May 24, 2011 | 08:06 AM
shiloh51933's Avatar
Nice build, I'll be there one day when my motor has 200,000+ miles on her. I still have about 50 thou to go and she runs like new, so I'll stick with the boltons til then..
Old May 24, 2011 | 06:13 PM
3rdmaxse0's Avatar
Ordered bottom insulators for the injectors today since mine are half torn or cracked.(Don't need a vacuum leak been there done that and no more rtv sealant bandaids for me) painting valve covers rear is done front needs lots of attention. Then I just need to clean up coolant pipes and housings and new fuel lines on rail and ill be snapping clips together. Tell you what though this is one of the easiest engine swap or replacement I have done, everything lays out where it needs go be no B.S.
Old May 24, 2011 | 06:17 PM
3rdmaxse0's Avatar
And shiloh don't count on your motor going in the 200k range mine went due to neglect not changing regularly and lost oil with asp pulley wearing in ( especially when I was on the dyno I had oil everywhere)
Old May 24, 2011 | 06:55 PM
James92SE's Avatar
So how in the world does that rear header clear the firewall? It looks like it'd be angled right into it
Old May 24, 2011 | 07:18 PM
3rdmaxse0's Avatar
I'll have pictures tomorrow its only maybe one more inch closer than stock manifold. Trust me I wad worried too.
Old May 24, 2011 | 07:55 PM
Matt93SE's Avatar
STFU n00b!
Mine was tracked from 160k to 225k with a JWT ECU. spun 7000rpm on a daily basis for several years.
finally stretched a rod bolt and came apart on me. at redline in 4th on the track. At Maxus no less. At least it died a noble death.
Old May 25, 2011 | 02:41 PM
3rdmaxse0's Avatar
ok heres the pic of the rear header just sneaking beneath the rack
Old May 26, 2011 | 07:12 AM
Nice man, are you going to paint the rear valve cover?
Old May 26, 2011 | 12:28 PM
maximo018's Avatar
That is the rear that is painted. I believe he mentioned in an earlier post that he still needed to paint the front.
Old May 26, 2011 | 01:37 PM
Oh yeah. Nice color. I did mine blue.
Old May 26, 2011 | 03:23 PM
xx-Marshall-xx's Avatar
kthxbye2u
I am jelly...
