Parking brake sticking
Old May 31, 2011 | 08:41 AM
cardana24's Avatar
Blown
Recently this problem has been getting worse for me. When I drive car in the morning after the car has been sitting overnight with the e-brake on one caliper or the other does not release when I take the brake off (does not happen every morning but it's getting more regular). Both calipers are less than a year old. Is this a common problem? I am guessing there is a problem back at the junction (by the spare tire) where it branches off to either side. The reason I say this is because its either one side or the other that will stick, but usually not both. Any one with experience with this? If it matters my car is a 92 se, I have Z31 rotors in the rear as well.
Old May 31, 2011 | 09:17 AM
Greeny's Avatar
¯\(°_o)/¯
It's the cables going from the handle to the caliper..they seize up inside...
Old May 31, 2011 | 10:44 AM
cardana24's Avatar
Blown
So just get a new right a left cable? Is there another fix? According to rockauto they are between 60-70 each.
Old May 31, 2011 | 11:35 AM
Greeny's Avatar
¯\(°_o)/¯
no other fix that i know of...you could check your local j-yards for some..just be sure to get them off a rear disc 3rd gen, as the drum cables are different..
Old May 31, 2011 | 01:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
not only that, but the caliper-side fitting changes based on year. iirc the 89-90 style is the same as the handbrake-side (cylindrical), but the 91-94 is a rectangular hook
this should be the same type that cardana has (since z31 rotors require the later style caliper)
Old May 31, 2011 | 02:02 PM
CMax03's Avatar
Just replace the cable if that's already been isolated as the actual problem.....I would disconnect the caliper E-brake cable end and the ebrake handle end as well to ensure it's the L/H or R/H cable or both!
Old Jun 1, 2011 | 10:42 AM
Brew's Avatar
Or you could try taking the cables off and getting some WD40 down inside of them. Always worth a try.
Old Jul 26, 2011 | 07:08 PM
shootingxblankz's Avatar
their right the cable is the problem it worked for me.
Old Aug 2, 2011 | 06:05 PM
94VEmaxpax's Avatar
just replace the cable wd-40 will only buy you a little time.
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
