are rear camber adjustments necessary?
Old Dec 25, 2001 | 03:38 PM
ngthing's Avatar
are the camber adjustments necessary for the rear? and, is 1 degree of adjustment enough for the fronts? i checked spec prod and the rears are expensssive! if I can just pick up the front, I'd be happy
#81250 front with adjustment up to 1.75 degrees $29
#67010 rear adjustment up to 2.75 for $99
Old Dec 26, 2001 | 05:46 AM
nismo1989's Avatar
Re: are rear camber adjustments necessary?
The rear are just as important as the front. It all depends on how off your camber is from spec. Have you gotten this checked? You need to go to a specialty alignment place and have them tell you how off it is. Then, you need to adjust the plates accordingly with the car hooked up to the machine. If the front is cool, but the rear is way off, you'll chew the tires off in no time, especially if you drive hard. If you camber is anywhere near a whole degree off I recommend spending the $99...
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
