(HELP)need to remove 93 max se top intake to replace rear injectors
Old Jul 29, 2011 | 03:39 AM
jona571's Avatar
is this a hard job removing the top portion of the intake to replace the rear 3 injectors?? 1993 maxima se model,,,and will I need only one gasket?? thanks to all who can help,,Iv done the mustang 5.0 before is this close to that type of intake??
Old Jul 29, 2011 | 05:56 AM
Hectic's Avatar
The hard part is getting the injectors out of the rail, unless you don't mind damaging them. Taking the plenum off is just time consuming. You only need 1 gasket if you take the plenum off with the throttle body. Over the years I've read some people say to remove the TB, but there's no reason to.
Old Jul 29, 2011 | 08:33 AM
Augustus Maximus's Avatar
Yeah just pull the UIM without taking off the TB in place, it's less work. Injector is not hard to get out either.
Old Jul 30, 2011 | 03:02 AM
Maxkiller's Avatar
Here is a tutorial written by one of the org members. It's pretty comprehensive. Be sure to read the thread as well, has a few experience points not specifically noted in the tutorial.
https://maxima.org/showthread.php?t=...hange+tutorial
Old Jul 30, 2011 | 01:32 PM
jona571's Avatar
I get blank page 404????
Old Jul 30, 2011 | 09:32 PM
maximo018's Avatar
OOO This sounds fun. I currently have mine off now.
Old Jul 30, 2011 | 09:52 PM
maximo018's Avatar
I leave some of my vac hoses hooked up. So I just flip mine over to the side (trans side). You have to disconnect the hoses in the back and unbolt from the support brackets that are bolted to the rear head. Of course remove coil packs, throttle cables, breather pipe, IM studs, vac piping to TB and IM on TB side. KEEP TRACK OF WHAT HOSES GO WHERE! Always my issue upon reassembly. Once you've done all of that you'll see the rest of what you need to remove (not much) air valve solenoid (whatever its called) etc. As Hectic said not hard just time consuming and tedious. As for the injectors my index finger and thumb developed blisters and were sore. Twist back & forth while pulling up. Once edge is up a bit use a flat head to pry the rest up and out.
Oh! If they've never been replaced before then you'll need an impact driver to remove those lil screws for the pinnacle caps. A screwdriver will strip them and make the rest of your day a living hell. Upon reassembly replace with new hex head screws from hardware store. I got mine from Lowes. Now life is easier with a 8mm when I have to change them out.
Old Jul 30, 2011 | 10:47 PM
BenStoked's Avatar
Jesus was a Zombie.
Unfortunately, that link is for a vg engine (leads to this, eventually..
http://www.caraudiohelp.com/nissan_m...e_tutorial.htm )
Old Jul 31, 2011 | 03:28 AM
Maxkiller's Avatar
Yeah sorry, I'm from Aus. We only have VG here so force of habit to assume, especially when not specified.
Carry on!
Old Aug 1, 2011 | 09:24 PM
jona571's Avatar
how long did it take you total??and do you know how many gaskets I need? thanks for your help
Old Aug 1, 2011 | 11:48 PM
maximo018's Avatar
Thing is the more you do this the faster you get. If you've never done it (obvious as to why your asking) it might take you 2.5 hours. You would need one gasket (intake manifold gasket). I suggest you buy o-ring kits for the injectors you are replacing. If not you'll end up having to go back in there to correct your mistake. Which means more money and time burnt.
Old Aug 8, 2011 | 12:08 AM
jona571's Avatar
job done
thanks guys for all the help,,things went pretty smooth just had to use a screw driver to get the injector out it was a *****,anyways firing on all 6 now but I'm still not happy with the power of the car,,seems to lack pick up when I hit it,,,so now what,,also I have 3coils cracked(front)and maybe I still have the original fuel pump in it still and I do have 217,000 miles on the clock and maybe shes just tired,,and I also have the vtc's grounded any Ideas???
Old Aug 8, 2011 | 08:23 AM
torqueymonster's Avatar
Shoulda done the Knock Sensor when you were in there, man...
Old Aug 8, 2011 | 05:05 PM
maximo018's Avatar
Yeah its gonna be a PITA later. But you will get faster at it the more you have to do this.
Old Aug 9, 2011 | 08:47 AM
I think
that the knock sensor is bad-- thus your lack of power.
Old Aug 9, 2011 | 12:39 PM
xx-Marshall-xx's Avatar
kthxbye2u
Man! Im trying to find my thread where I installed my intake spacers and changed my Knock Sensor at the same time... Its real easy though. Just start taking parts off. The annoying part is when you have to unbolt all the crap/support bracket on the back side close to the firewall. Have fun and remember where everything goes! No extra parts lol.
EDIT:
Found it! I could have sworn I had my own thread. starting at post #75... its not really instructions but ehhhh. It shows how far you need to go to get to the valley
http://forums.maxima.org/3rd-generat...ailable-2.html
HOKUSMAX
Nov 13, 2017 04:34 AM
Huttig2009
Sep 25, 2015 03:31 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
