Easier way to remove the oxygen sensor from plug?
Old Aug 8, 2011 | 06:23 PM
maxinout93's Avatar
Trying to replace my o2 sensor, and im catching hell tryna remove it from the plug. Any suggestions?
Old Aug 8, 2011 | 09:13 PM
CMax03's Avatar
Spray it with PB blaster and let it set over nite!
If that doesn't work turn it with a hammer and cold chisel and it will come out then! Be prepared to by a new one dude!
Old Aug 8, 2011 | 09:31 PM
khemraj1999's Avatar
i bought a cheap gas torch (Worthington Pro Grade WPK2301 Propane Torch $25) from home depot and heated it up. I learnt about PB blaster after and i heard some very good miracles about it!!
Old Aug 8, 2011 | 10:03 PM
maxinout93's Avatar
I will try the pb blaster method, I dont get it, I jus unplugged it yesterday, now it seems impossible to unplug.
road_warrior05's Avatar
Defintely vouching for the first two responses about the PB Blaster. That stuff works great on tight parts. I used it alot when I worked at Audi
Old Aug 9, 2011 | 06:20 AM
maximagician's Avatar
you mean the harness plug?should be a tab to lift on its side.
Old Aug 9, 2011 | 08:13 PM
CMax03's Avatar
??????? Any Luck???????
Old Aug 9, 2011 | 08:31 PM
maximo018's Avatar
PB Blaster+ Box wrench+ rubber mallet= success
Old Aug 10, 2011 | 03:00 PM
maxinout93's Avatar
Yea im talking about the harness plug, the sensor itself is easy to remove, its jus the plug to the harness thes giving me trouble.
Old Aug 10, 2011 | 05:21 PM
maximo018's Avatar
Oh in that case, is it covered in oily grit? Try using a set of needle nose pliers and a flat head.
Old Aug 10, 2011 | 08:57 PM
you push the tab down like a button(earlier i said lift the tab...oops)
the plug is hard to pull apart
Old Aug 10, 2011 | 09:46 PM
maximo018's Avatar
Sounds like your gonna have to shimmy it apart. If you sprayed PB Blaster on it (Oh the man upstairs) try and wipe off as much as possible or use brake cleaner to dry it out. PB Blaster+ electrical= fail.
Old Aug 11, 2011 | 11:20 AM
nc90gxe's Avatar
I had the same problem when I upgraded the y-pipe. Clean the heck out of it, then take a chisel or screwdriver and wedge it in right where the connectors meet and twist. even if you gouge out a little spot to make the chisel fit, you will not damage the holding tab on the connector. It behaves like a gm connector that has a rubber surround on the connector and is not letting air in while you pull on it , makes it a b**ch to pull out.
Old Aug 12, 2011 | 04:19 PM
maxinout93's Avatar
Ok I will try the chisel n screwdriver method.
Old Aug 13, 2011 | 10:11 AM
speedstick345's Avatar
PB Blaster + Wrench for sure. Nothing gets better than this
mvm062
Nov 30, 2020 09:00 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
