Home made CIA
Old Dec 29, 2001 | 10:59 AM
maximamusician's Avatar
Home made CIA
Has anybody taken out the black pipe coming from the filter box, that leads to the driver side headlight. If so, did you notice higher revs?
Old Dec 29, 2001 | 05:51 PM
Sudesh's Avatar
C-A-I
Old Dec 29, 2001 | 06:48 PM
flyry110's Avatar
i did that just before i made my pop charger. . . didn't really seem to make a difference except for sound.
Old Dec 29, 2001 | 07:22 PM
Gamezilla's Avatar
Did it sound better or worse? How do you make a custom pop charger?
Old Dec 29, 2001 | 07:44 PM
MaDMaX024's Avatar
intake making 101
goto a local shop and ask for a "mass air sensor adapter" for your max (i believe theyre all the same). next, pick up a cone filter and hose clamp.
remove everything from the MAFS *foreward* (as in away from the engine).
bolt up the adapter to the sensor, get some tubing if you'd like to route the filter inside the fender (like me)..
otherwise, pop on the filter, tighten the hose clamp and go for a ride.
for further excitement, remove the black hose/pipe between MAFS and TB, remove the big plastic thing that goes nowhere (intake resonator), find something to plug that hole...lots more bad@$$ noise.
Old Dec 29, 2001 | 07:54 PM
Gamezilla's Avatar
Re: intake making 101
I kinda get where you're goin. Are there pics of how to do this? A little extra noise can't hurt.
Old Dec 29, 2001 | 08:02 PM
flyry110's Avatar
i've posted pics before. try searching. what you do is remove the clam and the intake muffler. a jar lid actually fit perfectly in there!!! sounds crazy, but it works really well. if you want to make a pop charger, just drill out the 2 rivits in the stock air box, and remove the brass ring. bend that a little and you can just clamp the cone onto there. . . . . it works really well.
Old Dec 29, 2001 | 08:23 PM
MaDMaX024's Avatar
Re: Re: intake making 101
i dont have any pics...
as far as the noise goes, if you just make a pop and leave it at that, its alot louder. intake noise is much better than exhaust. i was very disappointed that when i added the CAI-ness to my intake, it got alot quieter, but i guess the power increase is worth it.
Old Dec 29, 2001 | 08:31 PM
flyry110's Avatar
my exhaust will defenitely be louder than intake hehehehe i did a pcv breather while i was at it too. . .
Old Dec 29, 2001 | 08:34 PM
MaDMaX024's Avatar
what does that do anyway?
hey, IM me, i'd like to know more about your exhaust..
my sn is BeaKMoneY (on AIM)
Old Dec 30, 2001 | 07:27 AM
Gamezilla's Avatar
http://forums.maxima.org/showthread....=intake+making
found it. No pics. And no link (sais there's supposed to be one, though).
Old Dec 30, 2001 | 06:25 PM
thanks for the correction. I've notice a little more pick up, took off the overdrive, and kept up with a L Dog up to third gear, after that he spit me out
Old Dec 31, 2001 | 12:12 PM
SuDZ's Avatar
Try changing fuel filter and cleaning throttle body. That can help you up top some.
SuDZ
Old Dec 31, 2001 | 05:15 PM
shavedmax's Avatar
Re: Home made CIA
[i did it when i changed my hl and i didnt notice a thing
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
