Bypass stock clarion amplifier?
Old Oct 24, 2011 | 06:47 AM
94beater's Avatar
CREDIT - ***Matt93SE*** Thanks!!!
Original thread on another forum found.... Here - http://blehmco.com/faq/rear_amp_bypass.txt
I was browsing some old threads and decided to start a new one rather than bring up a 3 yr old thread... How can I bypass the stock Clarion amplifier in my 94'? Are the wires that are run to that plug the speaker wires, and I would just cut them and splice directly to the speakers??? I dont wan't to just start hacking wires apart until I know I'm doing it right.
The reason I need to bypass the amp is because I just installed all new speakers and a new Kenwood radio, and my rear deck speakers are getting 90% of the sound.. The fronts are very faint. Fading via the head-unit does not help the situation. I know my front speakers have a lot of potential because I briefly disconnected the wire from the head-unit that powers the stock amp, so only the fronts were getting power and they sounded great!
***Edit*** After pulling out the plug and inspecting the wiring.... It looks as though all 4 speakers may be run off this thing??? I don't know why, but I was under the impression that the amplifier only powered the rear speakers... I guess I was thinking this because the rears were loud and the fronts quiet?!?!
Old Oct 24, 2011 | 10:29 AM
94beater's Avatar
Hours of searching online on multiple forums.... finally came across this.... Did it and it worked perfect!!!! Speakers sound crisp and clear and the volume is on the same level for all 4 speakers!
once you remove the amp, you'll have a connector with a dozen or so wires. the ones you need to connect are:
Large/ Small
Green/ Black-pink
Yellow/ black-yellow
Orange/ Orange
Blue/ Light Green
Simply connect the Large Green wire to the small black-pink wire, yellow to the black-yellow, and so on.
For particular left/right speaker identification, James Lofton (Jaybird180) supplied this info for me recently.
Yellow L+
Yel/Grn L-
Green R+
Lg Orange R-
Thanks, James!
These are the same wires you unplug from the amp. just cut them about
2-3" away from the end of the connector, so you can reconnect the amp
whenever you sell the car.
There will still be a few wires left on the
connector (power, ground, etc) just leave those connected to the thing,
that way you don't have to worry about loose power wires hanging around
back there. If you want to pull the amp out permanently, just be sure
to cover all the connections with tape or shrink wrap and then zip tie
it to the rear deck or something so it doesn't hang into the trunk.
It will all seem a lot clearer when you get back there
inside the trunk. btw, the easiest way to do this is to just grab a
handfull of butt connectors and get on your back inside the trunk. just
leave a leg hanging out so someone doesn't come along and shut you in!
Old Oct 26, 2011 | 11:22 PM
road_warrior05's Avatar
I'm about to try this because I've been having the same problem
Old Oct 27, 2011 | 06:20 AM
94beater's Avatar
It worked flawlessly and is really easy to do! I knew something was up because I put all brand new speakers and a head unit in the car... it definitely didn't sound good until I bypassed the amp. Now it has great sound out of all 4 speakers Just gotta install my amp/sub and I'll be all set!
Old Oct 27, 2011 | 11:43 AM
Yeah it sounds very good in the car now; however, it was a little more difficult for me because I had to squeeze behind the big sub box in the trunk
Old Oct 27, 2011 | 12:08 PM
94beater's Avatar
Hahaha thats going to be me in a week or so.... Just a matter of finding time to install everything into the max!
Old Oct 29, 2011 | 05:09 AM
maxinout93's Avatar
Large/ Small
Green/ Black-pink
Orange/ Orange
Blue/ Light Green
Yellow L+
Yel/Grn L-
Green R+
Lg Orange R-
Thanks, James!
So you are saying to remove the amp and all screws? then there is another wire connection???? If so then you just connect all the wires from the plug to the ones where the stock amp used to be, but not all the wires just the ones you are menchoning? My rear speakers stoped working a while ago after hooking up my stereo system. I think they are dead though, just havent gotten around to replacing them.
Old Oct 29, 2011 | 06:34 AM
94beater's Avatar
Originally Posted by maxinout93
So you are saying to remove the amp and all screws? then there is another wire connection???? If so then you just connect all the wires from the plug to the ones where the stock amp used to be, but not all the wires just the ones you are mentioning? My rear speakers stopped working a while ago after hooking up my stereo system. I think they are dead though, just haven't gotten around to replacing them.
I left the amp in the car... Just simply unplugged the connector and cut the appropriate wires... and connected them to the wires in that chart.....
Attach the large green wire to the skinny black-pink wire and continue the process for all of the wires... In the end you will have 4 connections. I will post a pic of the work I did to better explain what I did
Old Oct 29, 2011 | 06:47 PM
maxinout93's Avatar
[QUokOTE=94beater;8252133]I left the amp in the car... Just simply unplugged the connector and cut the appropriate wires... and connected them to the wires in that chart.....
Attach the large green wire to the skinny black-pink wire and continue the process for all of the wires... In the end you will have 4 connections. I will post a pic of the work I did to better explain what I did[/QUOTE]
Ok that would b great
Old Oct 30, 2011 | 06:37 AM
94beater's Avatar
Don't mind me using the wrong butt connectors ( Should have used those rounded wire caps) ..... But here is the disconnected plug that has the spliced wires
Old Oct 31, 2011 | 03:27 PM
Matt93SE's Avatar
STFU n00b!
Thanks for giving credit where it's due...
Old Oct 31, 2011 | 08:33 PM
maxinout93's Avatar
I will try that, and i always wondered how those connectors worked like the ones you have in the picture.
Ok that would b great[/quote]
Old Nov 1, 2011 | 02:41 PM
ujm's Avatar
ujm
Perfect timing, I'm getting ready to put a new stereo in mine and need to bypass that amp.
Old Nov 2, 2011 | 06:27 AM
94beater's Avatar
Glad my searching is helping some people out! I'm still really surprised at how much of a difference this made... The loud rear speakers/ quiet fronts was really frustrating!
Old Nov 4, 2011 | 05:16 PM
ujm's Avatar
ujm
Installed the new radio and bipassed the amp, all is now GREAT
Thank you
Old Nov 4, 2011 | 09:05 PM
Matt93SE's Avatar
STFU n00b!
Glad the writeup I did over 10 years ago is still floating around for you to cut and paste and repost without giving credit to where you found it.
Old Nov 6, 2011 | 09:54 AM
94beater's Avatar
Sorry man! Do you have the link for whatever site I found that on? I'd be glad to credit you for the initial write-up!
Honestly I copy and pasted it into Microsoft Word and printed it out so I could look at it while wiring it up in my trunk.
I never thought to save the link from where I found the write-up and I dont remember what web-site I found it on but I know it wasn't maxima.org.
Old Nov 10, 2011 | 12:15 PM
Matt93SE's Avatar
STFU n00b!
Lots of other interesting tidbits that most people have forgotten here as well:
(It's all in the stickies if you'll look deep enough, BTW.. The problem is there's too damn many stickies and too much crap to sift through to make it easy to find.)
Old Nov 10, 2011 | 02:18 PM
94beater's Avatar
Yeah the stickies do get pretty impossible to make useful... and the search function is not very effective anymore either.... just too much information everything gets mixed up!
Credited you in my OP
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
