Delayed 3-4 Upshift When Cold
Old Dec 31, 2001 | 05:15 PM
Gaijin
I'm a little concerned about the automatic transmission in my 1992 GXE. When cold (mornings or after sitting at work all day), it delays the initial 3-4 upshift for as long as a minute, causing the engine to rev to around 3000 rpm at 50 mph (as fast as I'll go until the temp gauge has climbed a bit). Once it finally does shift, the problem does not recur until the car has been parked and allowed to cool down fully again. This is admittedly a minor annoyance, but I have to wonder if it doesn't betoken some more serious mechanical or electrical problems. Any thoughts?
Thanks.
Old Dec 31, 2001 | 07:26 PM
Nismo87SE's Avatar
This is normal. The tranny doesn't engage 4th gear till the temp goes over 147*F.
Old Jan 1, 2002 | 12:05 AM
D-sta's Avatar
my uncle had that problem and he noticed that it would go away once it was warmed up. so the only thing i can suggest in which my uncle does and it works is to let it warm completely before driving.
Old Jan 1, 2002 | 01:45 PM
brubenstein's Avatar
According to the FSM, the fluid temp operating range is 50-80C (122-176F). OD will not be engaged until then. You really have to drive the car to get the temp up.
Old Jan 4, 2002 | 12:15 PM
GXEllent's Avatar
Delated-shifting tranny (cold weather)
OK, now how about a trans with delayed upshift from 2-3 and also from 3-4 but only when the ambient temp is below about 45deg F? This tranny shifted normally at all temps for the first 5 or so years but has gradually begun to do this delayed shift thing for the last two years.
The tranny oil has been changed periodically since the car was new.
I don't like to rev the engine too much when it's cold and I don't want to wait while the machinery warms up......besides, idling is not healthy for a gas engine.
My guess is that there may be worn seals in the valve assembly somewhere especially if there are spool valves in there somewhere that are sealed with o-rings. Any other suggestions? Is this a common problem?
Old Jan 4, 2002 | 12:17 PM
Jon91SE's Avatar
Pusssseeeehhhh
Re: Delated-shifting tranny (cold weather)
Its not a problem, and yes its common..........
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
jc53
Oct 6, 2015 06:00 AM
carlosvq30
Sep 26, 2015 09:44 AM
