possible vacuum leak ? (vg)
Old Feb 26, 2012 | 10:09 AM
max_overdrive's Avatar
i was working on the car today and i found this,what does it control? i think its giving me a vacuum leak.
Old Feb 26, 2012 | 10:48 AM
maximo018's Avatar
Thats the egr solenoid. I believe regulates the flow for egr. The green if your wondering is the power valve solenoid. Yes replace it.
Old Feb 26, 2012 | 07:11 PM
Maxpwer's Avatar
No turbo, no care!
What makes you think it's causing a vacuum leak? Have you tried bypassing it?
Old Feb 26, 2012 | 08:27 PM
i have a off idle stumble that i cant figure out. only thing i can think of is a vacuum leak. i have replaced all injectors and gave it a full tune up. i have also replaced almost all vacuum lines and the others are still good. i saw this and thought it might be the problem. i haven't bypassed it but i did seal the crack and it made no difference.
Old Feb 26, 2012 | 08:41 PM
maximo018's Avatar
James92SE had the same issue but had a replacement on hand. I believe the same one cracked on him.
Old Feb 26, 2012 | 08:54 PM
maximo018's Avatar
I also had a my own irregular idle today, but figured it out before I quit for the day. My IACV was leaking
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
followthadollar
Sep 17, 2015 06:31 PM
