1993 Maxima Timing chain. V-6 DOHC
Old Mar 18, 2012 | 10:27 AM
Kiron Kid's Avatar
My previous 93 Maxima timing chain skipped a link or more when I turned the car off, and destroyed the compression in three cylinders. It had over 224,000 miles on it. I have the chance to get another 1993 Maxima with 124.000 miles on it. If so, should I have the Timing chain tensioner, etc, looked at? How far are you guys going on the same timing chain. It is a chain, not the belt model.
Russ
Old Mar 18, 2012 | 10:33 AM
chrome91's Avatar
general rule to go by on chains is they will make a noise when problems start to arise
Old Mar 18, 2012 | 10:50 AM
Kiron Kid's Avatar
Thank you for the reply. What type of noise do they make when going bad? Also, from what I hear, it's common for this particular engine to make "ticking, deisel" sounds from time to time?
Russ
Old Mar 18, 2012 | 11:35 AM
chrome91's Avatar
sound youre hearing may be VTC clacking or just the injectors pulsing
timing chain noise sounds like this
Old Mar 18, 2012 | 11:59 AM
Kiron Kid's Avatar
Thanks. You guys are awesome. I've been told that you can ignore the occasional VTC clacking. Is this true? My previous 93 Maxima ran great. The mechanic says that the chain must have skipped when I turned the engine off. When I came back out and tried to start it, nothing. Lost compression in 3 cylinders. Before that, my only problem with it was a faulty Mass Air Flow sensor. An easy repair.
Russ
Old Mar 18, 2012 | 01:11 PM
chrome91's Avatar
its not really a huge problem, you can ground them for a temporary fix or you can replace them. i think the majority of people dont do anything about it
Old Mar 18, 2012 | 10:14 PM
KenBob's Avatar
That chain sounds lovely!!
Old Mar 19, 2012 | 07:49 AM
amdgoodez's Avatar
Ive had 3 Engines in my Ford Explorer 2 of them went bad because of their Timing Chain and I would always hear that scratching noise on start up but when I took it to my mechanic he said it wasn't a timing chain. Obviously I need a change of mechanic.
Old Mar 19, 2012 | 08:01 AM
Kiron Kid's Avatar
I wish my Maxima chain had given me some notice. it sounded and ran great. Until, the last time that I turned the engine off. Stopping the engine caused the chain to skip and tear up three cylinders :-(
ah2002
Mar 9, 2016 01:42 PM
Finkle
Sep 27, 2015 09:53 PM
laparka66
Aug 6, 2015 09:36 AM
