91 maxima
Old Mar 22, 2012 | 05:33 PM
diazjrgil's Avatar
91 maxima
My A/C is throwing out regular air, what could be the problem with that? the heat is good and blows out good air but just not cold anyone help?
Old Mar 22, 2012 | 05:53 PM
Amerikaner83's Avatar
do you need a re-charge?
Old Mar 22, 2012 | 06:02 PM
chrome91's Avatar
probably need a recharge, cant remember but i think it was December '91 onward that went from R12 to R134. dont quote me
Old Mar 22, 2012 | 07:02 PM
jbbons25's Avatar
R-12 was on the 89-92 models. 93 to 94 have R-134a.
If it is not blowing cold air, then there is a leak somewhere. It will need to be charged with a UV reactive dye and use a UV light to find the leak. Most likely due to its age, the seals are worn out, so it would be recommended to change all seals on the hoses.
Unfortunalely, problem with today is that R-12 is no longer available to get (easily), so it will need to be retrofitted for R-134a. Some auto shops will "retrofit" by just inserting the R134a adapters and just charge it with R-134a from there, but a couple of other parts have to be changed for a proper retrofit. But some have gotten away with just a charge, so it's a crap-shoot.
Old Mar 23, 2012 | 06:17 AM
Maximan190's Avatar
When i was doing my engine swap and engine bay cleanup/repairs, I treated my A/C lines like a fragile tube of glass, carefully working around not to disturb or rupture them.. did not want to open up that can of worms. My R12 A/C still and always has worked wonderfully
Old Mar 23, 2012 | 07:07 AM
CMax03's Avatar
My tires seem kinda flat and squarish not circular on the bottom portion touching the road and my rims are almost touching the ground...Do you think I need more air in them? Similar question being asked in this thread!!!!! Come on... use that brain! Either check your a/c levels with a guage or look into your sight glass of the accumulator.....Or just take it too an a/c shop that's doing free a/c inspections!
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
