humming from speakers
Recently my OEM Bose stereo head unit went out so i switched it out to and aftermarket sony. Since then i have a humming noise coming from the speakers when i accelerate. When i unplug the radio the humming goes away and is only there when i have my foot on the gas pedal. I still have the OEM bose speakers and the OEM amplifier. Any suggestions on how i can get rid of this annoying sound?
Did you use good wiring? Sounds like some rf interference to me. Make sure all of your wires are covered good. Are you using an aux device to play? Make sure you equalize the volumes so you don't have to turn the volume all the way up and max out the HU amplifying abilities. Provide more info for better solutions
yes the wiring is all good and connections are all good, i've installed about 30 radio's and have never had this problem. this is the first time im installing a radio in a maxima though. I thought it might have something to do with the black ground wire. i read that the ground wire should not be connected to anything, which it is not. I tried grounding the black wire but it just made it worst. im not using the aux mostly just cd's and the radio but it happens on both settings.
yes. i had a friend hook up some subs and had the same buzzing noise. i helped him rewire starting with the ground wire first. turned out that his ground wasnt fully connecting to the frame. i guess ill pull the wire harness out and try a soldering gun and solder the wires together to establish an accurate connection. ill update by the end of this week. thanks.
You need a ground loop isolator, Sony decks, especially old ones, do not have them built in. I GUARANTEE this is your problem.
It has nothing to do with the Bose system, although you should still replace your speakers and bypass your amps so the impedance of your speakers matches that of the head unit.
im not using any RCA's though, i thought those were if you were running RCA's?
The type I'm talking about goes in line with the positive lead.
http://www.ebay.com/itm/PAC-CSS-12-C...item1e6c789324
Search noise filter.
I bought one of those for my system to try to eliminate speaker whine a while back. It didn't fix my problem and degraded the sound quality noticeably.
^yup. good stereo won't need **** like that. Pay more, get more.
I've spent hundreds on cheap audio components and trying to fix the associated audio problems, then spent half as much, got a real deck, real speakers, and the problems "magically" went away.
Likewise, a quality noise filter isn't going to degrade sound quality. Pioneer used to include in line filters on the stock harness. Modern decks have circuitry built into the unit that either filters or accepts the erratic source.
I haven't used an aftermarket filter since I bought my first new deck in '97 (Sony), but I believe all it is is just a voltage regulator to clean up the dirty power coming from the battery and alternator. So it's actually not a ground loop isolator, that's what I was told it was called back in the day, so it's the first name I thought of, which is wrong. Anyway, I noticed no difference in sound quality except that the alternator whine was eliminated.
You ground the unit and connect one wire to your 12v source, the last wire connects to the (non constant) 12v input on the deck. I'm sure it will come with instructions that will specify which side the yellow and blue wires should connect.
Wait, what do you mean you don't have the black wire connected to anything? Black is ground, if not grounded properly, you just might have a loop on your hands. I'm going to assume that you have the deck bolted up to the stock brackets, which should provide a sufficient ground. If not, then it's grounded via RCA or some other weak point which is no good.
magiconthetire
10-26-2015 09:03 PM
Kyle Lee Cleveland
09-28-2015 07:58 AM
