Trick to compressing stock springs?
I'm nutty for Nissans
![](https://maxima.org/forums/images/smilies/support.gif)
I pulled some oem quick struts off a 3rd gen a few years ago. I took them apart back then to test the struts. I never got around to putting them back together. Here I am now trying to reassemble them. The struts are so short unlike 4th gens. I can't compress them enough to put them together. Do I need two sets of compressors?
Even with one of those compressors it can be tough to get them down far enough. Like you said, they are very short. Just make sure they are aligned properly in the mount, use the compressor, then have a fat guy hold the spring down so you can get the bolt in the top
Honestly how I did it!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
You might have to have the other compressor holding 4 coils while the other has 3. That's what I did. When decompressing the spring, one compressor might be caught at the final top (or bottom) coil. Just make sure you will have enough space to slightly whack the compressor out of the spring.
