how low of a profile should i go?
Old Jan 4, 2002 | 08:54 AM
nstymax93's Avatar
I have 16" wheels. i currently have a 55 profile but want a lower profile, which would look better 50 or 45?
Old Jan 4, 2002 | 08:59 AM
Matt93SE's Avatar
STFU n00b!
use 225/50/16 tires. anything with less sidewall will really screw up your speedo, and make the car look like a hooptie. might as well throw some gold spokes in there if you do that.
Old Jan 4, 2002 | 09:09 AM
nstymax93's Avatar
but can you really tell a difference between the 50 and 55's?
Old Jan 4, 2002 | 09:16 AM
DanNY's Avatar
Ad·min·is·tra·tor
hey! gold spokes are PIMP!
Old Jan 4, 2002 | 09:20 AM
Matt93SE's Avatar
STFU n00b!
in handling, yes. in profile size, not much- IF you have the correct sizes to begin with.
215/55 is the correct size for 16s.
225/50 is a little wider, and slightly less profile. it's actually about 5% shorter circumference than stock, so it'll throw off your speedo a tiny bit.
225/45 will really throw your speedo off, and it starts to look dumb. huge wheel well gap.
Old Jan 4, 2002 | 09:30 AM
nstymax93's Avatar
Well i dont have stock wheels i have concept neeper rapter 16"s w/ 205/55/16 tires. Also my car is lowered (intrax). just letting you know incase you didnt.
Old Jan 4, 2002 | 09:48 AM
Matt93SE's Avatar
STFU n00b!
okay.. well 225/50 (112.5mm) will have almost the exact same sidewall height as your 205/55s (112.75mm), but they'll be an inch wider. should make for quite a bit better handling and it won't change the looks at all.
Old Jan 4, 2002 | 11:04 AM
nstymax93's Avatar
thanks alot i think ill go with the 225/50/16
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
