Brake Light
Old May 18, 2012 | 10:49 PM
rmdl51's Avatar
White_Shadow
Brake Light
Hello Guys, This week I noticed a problem while driving my Maxima, the red brake light does not go off when I release the hand brake, it seems to go out after driving a few minutes but today I drove about 15 minutes and nothing, until a brake a bit hard and then disappeared, I don't know if this could be any sign of further mechanical problem or just the annoying red light on the dashboard.
What could be causing this problem? Thank you.
Old May 19, 2012 | 02:31 AM
Laevateinn's Avatar
Does your max came with ABS?
If not, most likely it's a sticking proportioning valve (it's integrated with the master cylinder). Due to age and dirty fluid, debris can buildup inside a valve bore, a sudden flow of fluid can break it loose clearing the path of the valve.
3 Things that cause the red brake light to illuminate:
1. Low Brake fluid level
2. Parking brake engagement and/or parking brake switch
3. Unequal fluid pressure of front vs rear (may include driver vs passenger side)
Old May 19, 2012 | 09:40 AM
rmdl51's Avatar
White_Shadow
I'm not completely sure but I remember checking before and it comes with ABS, (don't remember how to check).
I just check my brake fluid and is a little below the min level, I didn't know this could cause the brake light to come on, I remember someone told me: "don't refill the brake fluid if your fluid level is low is because you need new brake pads" is this statement true?
Old May 19, 2012 | 05:39 PM
Hectic's Avatar
It's your fluid level. Which of course can indicate that you need new pads if the declining level is not caused by a leak.
Old May 19, 2012 | 08:53 PM
rmdl51's Avatar
White_Shadow
I don't think is leaking, I have not seen any leaks, and I have not done brake service in about 4 years (rears were done 3 years ago) so this as you point out it might be the need of new pads, now the question is should I fill up my brake fluid level in the meanwhile before replacing new pads? (because I can't do it right now, maybe next week I will) Sorry for my ignorance I really don't know much about brake systems. Thank you for your help
Old May 19, 2012 | 09:16 PM
brads91max's Avatar
Yes you can fill itt for now but because your fluid is low you might want to bleed them too when you add more fluid
Old May 20, 2012 | 12:54 PM
Laevateinn's Avatar
Just remember to push the pistons back with the bleeder valve open to avoid pushing debris back into your system.
mvm062
Nov 30, 2020 09:00 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
