coolant leak?
Old May 26, 2012 | 12:37 PM
BklynsmoeVE's Avatar
coolant leak?
Today I noticed a relatively small puddle of coolant right underneith where you would drain the oil from. I also noticed a streak of coolant hanging along the side of where we would drain the oil from..sorry I really cant think of the name atm I want to say oil pan..but dont think thats the correct name.
Anyway my question is where could this coolant be leaking from so far back..seems like its trickling down from around the pulleys..im assuming this is my waterpump thats leaking? Im use to seeing coolant leaks closer to the bumper around the rad area never seen coolant further back right behind the oil filter before. I do have 216,000k with original WP I believe...
thanks guys.
Old May 26, 2012 | 12:51 PM
jbbons25's Avatar
I don't know if the VE water pump if it has one, but on the VG pump there is a little hole on the bottom of it that starts to leak when there's something wront with it. It happened to me, so I'm guessing that it's happening to you.
EDIT: Looking at the RockAuto pictures, the VE pump does have the small hole. So check to see if it's coming from there.
Old May 26, 2012 | 01:02 PM
James92SE's Avatar
2 VE's are better than one!
Is it on the passenger side of the engine near the belts/pulleys? Your water pump is right up there, so if it's leaking from that side of your engine it's almost definitely the WP.
I can't believe you've gotten over 200k on the original water pump. All mine have gone out well before that.
Definitely "splurge" for an OEM unit. I've had terrible luck with aftermarket VE pumps, and have had to re-do them with OEM ones. It's definitely not a fun job and really stinks to have to re-do it due to an inferior aftermarket unit.
Old May 26, 2012 | 03:22 PM
Yeah I went back and checked and I believe it is coming from this hole your talking about.
yeah exactly there on the passenger side of the engine bay. heh yeah thanks for the heads up its only about $90 ive heard of worse for oem parts. Is there anything else I should watch out for while im already doing the WP? The steering pump is original aswell and I believe its in the process..
Old May 26, 2012 | 09:32 PM
chrome91's Avatar
sounds like the waterpump to me as well. only other things you should really do at the same time is replace the thermostat and replace the radiator cap and put new coolant in
and as said go for a OEM waterpump, aftermarket ones can be a pain sometimes
Old May 27, 2012 | 11:22 AM
James92SE's Avatar
Where did you find an OEM for $90? That seems pretty cheap, IIRC the OEMs I've bought in the past were always $160+
Old May 27, 2012 | 12:50 PM
maximo018's Avatar
Our cars are becoming obsolete.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
