What happened here?
Old Jun 20, 2012 | 05:30 PM
Maxtastic GXE's Avatar
What happened here?
Hello I had a strange transmission incident happen to me driving my maxima.
I was coming up to a red light (under 30mph) in Drive,the light turned green (less than 20 feet) I gave it gas (about half throttle) it down ****ed to 2nd and then it wouldn't upshift too drive. So it was stuck in 2nd it reved up to 3500rpm I tried to manually shift from 2nd to D..no effect..I thought the worse ( i was on my way to LA) so I pull over and put the car in park, while still running I put it in D it went into gear,started driving it shifted from 1 to 2 kept going and it shifted and drove fine the whole trip afterwards... "What happened?" I did just changed the tranny fluid a few days prior FWIW (used Dex 3) Thanks in advance.
Ernesto
Old Jun 20, 2012 | 05:44 PM
Greeny's Avatar
¯\(°_o)/¯
maybe it had the hiccups..
Old Jun 20, 2012 | 06:38 PM
chrome91's Avatar
check your tranny fluid level, could be a bit low. happened to me once, tranny fluid got a bit low and i had the odd slip like that
Old Jun 20, 2012 | 10:38 PM
maximo018's Avatar
Ernesto
Your valve body had a B.F.
Old Jun 21, 2012 | 07:25 PM
Dhunterx's Avatar
Could be your transmission computer going on the fritz. It happened intermittently to me, and I knew something was wrong when the "auto/power" switch light wouldn't turn on. Ordered a TCU on ebay on a hunch, replaced it, and it's been working fine ever since.
Old Jun 22, 2012 | 12:49 AM
CMax03's Avatar
Maybe a solenoid or clutch piston was sticking!
Old Jun 22, 2012 | 02:47 AM
maximo018's Avatar
Or it could be as simple as that.
Old Jun 30, 2012 | 02:28 PM
Hmm, all good suggestions...occasionally when in OD the convertor will lock and unlock and the RPM's will fluctuate about 300 rpm's....still sounds like a transmission ECM problem still. Tranny fluid is fine. BTW
Old Jun 30, 2012 | 02:44 PM
ShocknAwe's Avatar
Probably just getting used to the new fluid. I have heard of tranny's acting strange after a change. Esp. a sex change....
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
