TPS on a 1989 maxima gxe VG30e
Old Jul 6, 2012 | 12:10 PM
89 Maxima owner's Avatar
can anyone explain the proper way to set the tps on this car in terms that I can understand. first all the motor has been rebuilt, the maf sensor, the iacv motor, tps, distributer, ecu, EFI wiring harness, there is nothing as far as sensors that have not been replaced on the car. I bought the tps from autozone. how do u adjust it I need the whole process.
Old Jul 6, 2012 | 07:21 PM
maximo018's Avatar
Eww. U bought it from az. I learn my leason when about buying sensors from other places than Courtesy. The FSM has a step by step way at setting the ecu to adjusting the tps. I can't remember the procedure the exactly.
Old Jul 7, 2012 | 09:27 PM
what is FSM
Old Jul 7, 2012 | 09:53 PM
maximo018's Avatar
what is FSM
Factory Service Manual. Google it or better yet search here on the org and you'll find it.
Old Jul 7, 2012 | 09:55 PM
maximo018's Avatar
Should be the same for a 94 VG except for injectors.
Old Jul 9, 2012 | 01:16 AM
Hectic's Avatar
About the TPS.. Yeeahh, did you get the memo?
Old Jul 9, 2012 | 09:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
loosely screw on tps. measure resistance out of the plug until it's to spec...tighten screw. confirm resistance is ok after tightening.
schmellyfart
Sep 25, 2015 04:47 PM
Ray229Harris
Sep 16, 2015 08:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
