5spd swap...clutch pedal issues
Old Jul 12, 2012 | 12:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
is there something there that i can mount the top bolt to or will i have to go without the top bolt?
also is there a spacer that goes on the firewall. does it go flushed to the firewall sheet metal? is there a spacer? the mounting studs seems to be super long...long enough to have something in between.
thanks
Old Jul 12, 2012 | 01:34 PM
DanNY's Avatar
Ad·min·is·tra·tor
ok found the top bolt...but it's a good distance from the firewall...now what?
Old Jul 12, 2012 | 07:33 PM
89boostedmax's Avatar
there is a spacer that goes in between the pedal assembly and firewall and when i done my 5spd swap i had to drill the hole in the firewall also.
Old Jul 12, 2012 | 08:21 PM
maximo018's Avatar
What! Danny have a question for us instead of for him? Lol Anything can happen. So you finally gonna make the GXE a 5spd. Finally some action from this man. Now if we can get Wayne to join in the 3rd gen section might actually have a beep on the heart monitor.
Old Jul 13, 2012 | 05:40 PM
Greeny's Avatar
¯\(°_o)/¯
thanks
scrap the car...it isnt worth the work
Old Jul 13, 2012 | 05:41 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jul 13, 2012 | 05:56 PM
DanNY's Avatar
Ad·min·is·tra·tor
greeny...thanks for the LACK of help
Old Jul 13, 2012 | 05:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
is it a part that i need to buy or is it part of the f-wall on manual cars that auto cars need to fab up or something?
DanNY's Avatar
Ad·min·is·tra·tor
hey it happens...i'm don't know everything.
Old Jul 13, 2012 | 09:14 PM
maximo018's Avatar
cofl stupid
Old Jul 13, 2012 | 09:16 PM
maximo018's Avatar
I'm not currently with my car to tell you accurately. But I thought the shells were the same regardless of engine or trans. I won't be able to confirm until tomorrow evening.
Old Jul 13, 2012 | 11:59 PM
Hectic's Avatar
No "spacer", but the soundproofing material between the mount and firewall is supposed to be there. It's a good half inch worth of foam and that hard black moulding. Might want to hit up the junkyard and cut out that area of soundproofing from a stock 5 speed and graft it in there.
Old Jul 14, 2012 | 06:59 AM
it does have the soundproofing but there is a spacer that is spot welded to the fire wall once the pedal assembly is out of the way you can bend it back and forth to break the spot weld. if you need one i think there is a 5spd car at my local pullapart just let me know.
Old Jul 14, 2012 | 07:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you can get it that would be great.
just for reference i'm referring to the spacer between the pedal and the firewall (the two studs from the pedal bracket) not the top bolt.
the sound proofing crumbles in my hand so i'm not sure how well that's going to hold up.
Mar 12, 2020 12:06 AM
220k+ A32
Sep 11, 2015 02:18 AM
ef9
Sep 10, 2015 10:35 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
jcvgn
Sep 10, 2015 08:03 PM
