I got a blown head lamp help???
Old Jan 6, 2002 | 09:49 PM
Maximus91's Avatar
ok my lamp is fried how can i fix it
The bulb is fine but the conector from the wireing to the bulb is melted where can i get it fixed and how much am igonna pay???
thanks maximus91
Old Jan 6, 2002 | 09:53 PM
BIGDOG's Avatar
Chances are youve got the blue bulbs in your car... Take them out if they are the 80 by 100 watt ones. They are just too much power. And they are melting the wires. This happened to mine and I took it to nissan to have them fix it. I dont remember what it cost but let nissan do it so you will know that its done right.
Bigdog
Old Jan 6, 2002 | 09:56 PM
Maximus91's Avatar
coool thanks man
so i cant get like heavy duty ones or anythin cause i like my lights
thanks agian
Old Jan 6, 2002 | 10:01 PM
BIGDOG's Avatar
Yeah I believe that APC makes a kit for them but you can also get blue lights at the regualr wattage. I have these now. 45 by 65 watts I think. Around 35 dollars.
Bigdog
Old Jan 6, 2002 | 10:02 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
man you can do it yourself.....$11 9004 harness from Nissan, cut/splice/connect(as they are in OEM sequence) the wires and boom you're all done, 10 minute job!
Old Jan 7, 2002 | 06:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
10 min!?!? rookie...
aftermkt connector..3-4 bucks from pepboys.
3 butt connectors and some electrical tape. good as new.
5 min tops.
Old Jan 7, 2002 | 09:02 AM
Maximus91's Avatar
alright
cool thanks for being sooo gentle
ha ha
Old Jan 7, 2002 | 09:16 AM
BIGDOG's Avatar
But you still need to change the lights out bc if you dont you will have the same problem all over again.
Bigdog
Old Jan 7, 2002 | 10:45 AM
DA-MAX's Avatar
hey, that also includeds prepping my fingers to deal with the 20 degree weather!
Old Jan 7, 2002 | 11:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
ok ok..u win that...drive into a garage!
Old Jan 7, 2002 | 02:31 PM
Sudesh's Avatar
yeah..strauss or pep boys sells the connectors for like $4-5 bucks.
I wouldn't stop using high wattage bulbs..the wires arent the problem..it's the pastic connector..it doesn't hold up well to the heat the wires generate.
Not all blue bulbs are 80/100. Alot of them are 40/50 or 55/65 and PERFORM like 80/100..so the wattage is actually low. ..i dunno this will always be a problem.
Old Jan 7, 2002 | 07:02 PM
Maximus91's Avatar
well i did it
i fixed by changing the plastic connector
thanks to everyone (Except the smarte alex)
anyway thanks guys much apperciated
Lates maximus 91
Old Jan 8, 2002 | 02:37 PM
Valadez_jr's Avatar
Re: I got a blown head lamp help???
thanks maximus91
I had the same problem. I spent a lot of money on the blue lights and put them in. They lasted a very short time until the wirh harness melted. If you pull the harness out I bet the right side of the harness is melted. That is the ground wire. What I did was buy thicker wire guage #10 and grounded it right on top to the body of the car. Of course you are going to have to go to Autozone and purchase 2 new wire harness. Pull out the ground clip in the harness bend the clamp to replace it with the thicker gauge and push it back in the harness. After that you ground it to the body and you ready to go
Old Jan 8, 2002 | 02:44 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: I got a blown head lamp help???
ok that's fine...so it won't burn at that 10ga..just at another location. it's as strong as the weakest link. it's best to run a relay and heavier wiring.
Old Jan 8, 2002 | 04:25 PM
Valadez_jr's Avatar
Re: Re: Re: I got a blown head lamp help???
Negative, I just talked to one of the technicians here at work and he informed me that as long as that negative wire is thick and grounded properly it will work. No relay is required.
Old Jan 8, 2002 | 05:32 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: I got a blown head lamp help???
where do u work?
the stock relays and switch...u think it's going to be ok?
if u say it's going to be ok..then i guess do what works for u...i ran relays myself.
Old Jan 9, 2002 | 06:49 AM
Valadez_jr's Avatar
Re: Re: Re: Re: Re: I got a blown head lamp help???
where do u work?
Where did you by thr relays and what are the part numbers? I want to check it out
Old Jan 9, 2002 | 07:17 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: I got a blown head lamp help???
well why would u need to check it out if you're are all good to go??
BTW...relays are 30A bosch (low beam) and 40A PB (high beam)
Old Jan 9, 2002 | 09:29 AM
Maximus91's Avatar
hey guys now my bulb is no longer blue???
On the side i replaced
is it cause the harness or the bulb ??
Old Jan 9, 2002 | 02:34 PM
DA-MAX's Avatar
make sure you re-wired it correctly, I wired mine worng the first time and the light was dull, fiddled around a little more with the wiring sequence and the light went back to being bright.
Old Jan 9, 2002 | 05:32 PM
Valadez_jr's Avatar
head lamp help???
[QUOTE]Originally posted by DanNY
That is all you did was add some relays and thicker wire? Well mine hasn't burnt out. I've had them grounded for five months. Hats off to you for your choice.
Old Aug 22, 2002 | 12:18 PM
MaxPower13's Avatar
Help! I have the same problem and dont know what to replace....PepBOys doesnt have a wiring harness and the dealer wants to replace all this other ****....what do I do??
Old Aug 22, 2002 | 11:36 PM
nismo280's Avatar
I've used stock wattage headlamps, and re-wired and replaced the fogs with some massive wattage super high output driving lamps by Piaa. Looks stock when the fogs are off .
Tony
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
homewrecker
Sep 24, 2015 07:01 PM
