VE and Vg guys step in
Old Jul 31, 2012 | 09:52 AM
Kountz430's Avatar
bald aggression est 78
what are the pro's and cons of rebuilding a vg verse's the ve i have a spare vg in the garage and i can score a ve from the junkyard for 150 164xxx miles. im talking in terms of aftermarket performance boost/spray opinions please
Old Jul 31, 2012 | 12:28 PM
DanNY's Avatar
Ad·min·is·tra·tor
whats currently in your car now?
Old Jul 31, 2012 | 02:23 PM
Kountz430's Avatar
vg 179xxx
Old Jul 31, 2012 | 05:12 PM
maximo018's Avatar
vg 179xxx
If you want to go turbo then a VG is the better option seeing as its been done before and can use parts from a z31 turbo. If want to be different then you could do a VE. It also has been done before but not in a while. Don't think any current members have one at this time. More after market for the VG since it was made up until 03. VE has more top end & vvt. Both are fun to work on, just these days the market is more in favor of the VG.
Old Jul 31, 2012 | 06:30 PM
Hectic's Avatar
Do you want your car to clack at idle or remain quiet and virtually inaudible?
I've had some fun abusing VE's when I've had them. But after a couple weeks, I can't wait to get rid of them and get back to my baby.
Old Jul 31, 2012 | 08:22 PM
maximo018's Avatar
Yeah the vtcs will talk but theres 2 ways around that. Either ghetto rig them (ground them out) or rebuild them. You sacrifice something from one motor to the next. VE: chain driven & direct ignition with 190hp VG: no vtc clack, easier for turbo build and more readily available. Its all preference.
Old Jul 31, 2012 | 08:57 PM
Chris Gregg's Avatar
Get Off My Lawn
IMO, the VG is just simply a more raw and moldable engine. So simple and easy to work on. As mentioned, aftermarket stuff for the engine is out there more so than the VE. You're going to avoid a lot of issues modding what your car is already fitted for, the VG.
The only complaint I'd have with the VG is the timing belt. However, that is a non-issue really if built properly. I mean, the VG30DETT is even belt driven. I'd just suggest if you have the square tooth belt, upgrade to the better round tooth belt (along with crank and cam components). Either way you go, do not skimp on replacing the oil pump....ask me how I know!
Old Jul 31, 2012 | 09:50 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Get one of each :-)
Old Jul 31, 2012 | 09:59 PM
maximo018's Avatar
I would agree if his budget would allow. :-D
Old Aug 1, 2012 | 07:13 AM
Kountz430's Avatar
yeah i heard about that clacking noise and that would just drive me stupid but then again that aint to far of a trip
Originally Posted by mrkanda
Get one of each :-)
see thats the thing i have three VG's 94 gxe 90 se and a spare one with a 5spd trans four if you wanna include my old J30
my neighbor said the same thing about the z31 parts,i was also looking for an all range performer meaning bottom end mid range and top end < if im puttin it out there right.but i have that feeling its gonna be extremely hard to get it perfect,cause i know i'll lose one for the other
Old Aug 1, 2012 | 08:17 AM
akurtzer57's Avatar
Vg30et all the way. Very easy to boost. Z32 injectors z31 manifold do have to do custom crossover move few things. I did all custom manifolds on mine. Can use vg30dett internals in the vg.
Old Aug 1, 2012 | 08:24 AM
maximo018's Avatar
I agree stick with the VG and put lower compression pistons from z32 turbo in.
Old Aug 1, 2012 | 01:06 PM
jbbons25's Avatar
VG33?
Old Aug 1, 2012 | 03:04 PM
Get Off My Lawn
VG33 is an option. Most don't consider it.
I disagree at the thought you have to sacrifice bottom end on the VG to gain top end. That's a misconception and really only applies if you're planning to boost over 15psi. Just simply build the engine back to stock compression at 9:1, keeping bottom end and mid range. Turbo comes on really early and maintains power to redline. I know I'm over simplifying here, but there is an easy way on these engines to have both.
I know I built mine to 8.5:1 and did lose some bottom end but hardly noticeable. And that was with a VERY aggressive cam moving my power into the upper rpm range. I suggest more a mild cam to bring power more mid-range. I suggest using Scneider cams. Theres just so much power down low as it is, unless you get an aggressive cam and drop compression to 8:1, then low end will be fine....trust me. My T3 spooled at about 1800-2k rpm and was at 8psi by 2600-2800.
Biggest decision is going to be turbo and cams.
Old Aug 1, 2012 | 04:05 PM
maximo018's Avatar
And there you have it from a fellow VG30et member who has been running on this way for... how long Chris?
Old Aug 1, 2012 | 06:59 PM
Get Off My Lawn
Running Several years, I'd have to actually look. LOL!!
I'm definately not the end/know/be all, lots of more knowledgeable guys. But, I can try and share my own experience and what I've learned.
Old Aug 1, 2012 | 10:18 PM
akurtzer57's Avatar
I run 100% stock bottom end heads ported polished schnieder cams /springs with Holset he351 on 18psi holding together well and I beat it pretty good. If going boost spend the money where needs to and do NOT cut corners!
Old Aug 2, 2012 | 08:20 AM
Get Off My Lawn
^^^_____ Cannot be emphasized enough!
Old Aug 2, 2012 | 08:59 AM
mrkanda's Avatar
So what's the best turbo for the VG in terms of rpm range and spool characteristics. I've been eying the GT35R myself.
Old Aug 2, 2012 | 10:43 AM
Get Off My Lawn
Can't tell you what is best. Going to be what you want to achieve mixed with choice and combination of injectors, cams, compression, engine management, and other supporting mods.
I suggest Corky Bells book on boosting. Might help with formulating what you want into what needs to be done to accomplish.
Old Aug 2, 2012 | 10:55 AM
akurtzer57's Avatar
Depends alot on what you are building car for goals in mind etc. GT35R depending on turbine size you go with will spool nicely. My Holset is similar in size and I see full boost by 3500rpm.
Old Aug 2, 2012 | 01:39 PM
mrkanda's Avatar
Does the DOHC and the VTC system on the VE make for a harder time with turbo set up?
On the VG how is turbo on the trans? I assume a 5spd is essential. How can a 5spd trans be built to reliably handle 350-400+ hp?
Old Aug 2, 2012 | 01:52 PM
Get Off My Lawn
If that's your goal, then
You need to prepare for some low end losses.
I'm out of touch with companies that build trannys. Level 10 was the thing back when I did my build, but I want to say they are gone, NOT certain. There are cryo treatments forthe gears and internals. You'll just have to search or maybe someone has current info for guidance.
Otherwise, need to go with a VE 5sp. Has beefier axles and an LSD to get the power to both wheels and the ground. Performance clutches are a dime a dozen. For a VE 5sp, you'll just need to swap out the hubs with tranny and axles. You'll also need to ensure you've got the 5sp carrier bracket for the passenger axle if you are currently an automatic.
Old Aug 2, 2012 | 01:54 PM
Get Off My Lawn
VE being tougher to build turbo? I'll defer to those who know better than I.
maximo018's Avatar
The man thing I here is the weak point is the differential. Have that cryo treated/ shot pinged along with the rest of the internals and you should be alright. No one else has done that yet so no proof of the results of that.
The VTCs shouldn't effect the spool much. If any I believe it would help. (not 100% accurate about that) check with either James or Brad for verification on that.
Old Aug 2, 2012 | 02:07 PM
mrkanda's Avatar
No one on here has a full write up of installing a turbo system on the VG or VE do they?
Old Aug 2, 2012 | 04:24 PM
maximo018's Avatar
If you want one for the VG go to the 2nd gen section. As for the VE its all custom.
Old Aug 3, 2012 | 12:03 AM
akurtzer57's Avatar
My vg trans is holding been trying to grenade it give me reason to put my ve lsd in. I'm pushing 400whp now tempted crank boost 22 see what happens.
Old Aug 3, 2012 | 12:15 AM
maximo018's Avatar
If it holds up to that then u r one of the few that slip thru the cracks. I'm pretty sure it won't hold out long after that.
Old Aug 3, 2012 | 05:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
if someone wrote it up would use actually go turbo or you just want to see whats involved?
Old Aug 3, 2012 | 07:09 AM
akurtzer57's Avatar
Biggest problem I am having is vc joints. Can't keep them together.
Old Aug 3, 2012 | 07:18 AM
Kountz430's Avatar
thanks fellas im not really shooting for extreme numbers but just enough to stirr the coffee and walk away for people when need be honestly i'll be happy with 250/ 275 if its higher than that when its all said and done is still good i was looking at this one here
http://www.full-race.com/store/garre...e-turbo-1.html
Old Aug 3, 2012 | 07:31 AM
Get Off My Lawn
There may be no official write up. However, at least a few guys have images of their builds up on cardomain. I know my images are there. Will give you ideas, then you choose what fits your goals and budget.
Old Aug 3, 2012 | 08:27 AM
maximo018's Avatar
Oh if you don't cut corners you will easily exceed that. I believe a while back I noticed that most of the turbo 3rd gens were making in the low 400- high 300hp.
Old Aug 3, 2012 | 08:30 AM
maximo018's Avatar
Are you on stock axles/autopart store specials? If so chat with the folks at Raxles. Thats what I did.
Old Aug 3, 2012 | 09:01 AM
mrkanda's Avatar
Yes, I would like to go turbo. I'm not sure how soon I can do it given budget concerns. As stated elsewhere I am still working on getting my old VG auto back, and then looking to buy a VE5 trans and swap parts and install that. I also have leads on a whole VE5 car for fairly cheap that needs some work and a built VE engine that I may also get. I was thinking originally to swap in a whole VE5 drivetrain in my old Silver '89 GXE with the built motor to get the best N/A performance possible, but now with the VE5 car available I may try to just keep the VG engine and go turbo with that later while doing the VE build in the VE car ;-) The only problem is I don't actually need two Maximas.... The wife probably won't like it. I plan to put in around $2500-$3000 for both cars. There's also a cool '96 BMW 318ti 5spd available for $1k, so what to do. Too many options - not enough money/time/space....
BTW, Raxles is in Gainesville, FL just down the road from me... literally about 10 minutes, just in case anyone needs any help with contacting them, etc...
Old Aug 3, 2012 | 10:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
oh VE turbo..yeah i can help you with VG turbo...VE i would have to defer to someone else.
Old Aug 3, 2012 | 11:26 AM
maximo018's Avatar
Either James or Brad. Its seems as though a few ppl are starting to take interest in turbo VGs lately.
Old Aug 3, 2012 | 12:03 PM
Get Off My Lawn
Someone should just buy mine then.
mrkanda's Avatar
Well, if I end up getting both cars, VG and VE, I'll probably use the built VE motor for N/A and turbo the VG. It's all theoretical until I get the car(s) in hand. Waitin' for a DWMH to sell before I have cash for anything.
