Is bad engine mount a serious problem?
Old Jan 7, 2002 | 08:59 AM
hclll's Avatar
Engine mount is nothng but 3 pieces of rubber, right? A mechanic said it is the bad mounts cause my Maxima to shake when stopping at a light. He said it is not a big problem to be fixed urgently.
I remember some guy here said bad mount finally will ruin the motor and tranny, is that true?
Do I need to replace the mounts? Shop said they are $100 each to replace.
Old Jan 7, 2002 | 10:07 AM
Matt93SE's Avatar
STFU n00b!
it won't do a durn thing to your engine to have bad mounts, but it WILL cause vibrations- both while stopped and driving.
the other drawback is that the engine sits in the engine bay crooked, and causes more wear on CV joints and stresses your exhaust studs. (with a crooked engine, the back of the exhaust is pulling on the Y pipe, which is connected to the engine through the exhaust studs- a known weak point on our cars)..
so I'd recommend getting it fixed when you can, as exhaust studs are $300/side to replace, and CV joints are about $200/side.
Sooo, there's $1000 in repair right there because you decided to put off a $100 job for too long.
Old Jan 7, 2002 | 07:26 PM
92ZexMaximaSE's Avatar
What do u think it could be if you have replaced your cv joints and still hear that clicking noise when you turn especially on cold days.
Old Jan 7, 2002 | 07:51 PM
DanNY's Avatar
Ad·min·is·tra·tor
shot in the dark...i'd say wheel bearing.
Old Jan 7, 2002 | 09:44 PM
male's Avatar
I'd say defective CV...Where did you get it/them. A clicking CV is very distinctive noise and there is really nothing else that will click when turning. A wheel bearing will make whirring cyclic noise when going straight and will chnage if you cut the wheel left/right at speed. Remanufactured CV axles are known for defects. I had a Subaru the took three tries at reman. axles before I bought USED, UNKNown milage axles that made No noise and cost 15 bucks each!
Old Jan 7, 2002 | 10:25 PM
Pervis Anathema's Avatar
Matt, engine mount replacement is only $100?!? I thought that the mounts alone were 3 times that much... What can I expect to spend for OEM parts and a professional mechanic?
Old Jan 7, 2002 | 11:15 PM
Sudesh's Avatar
Matt,
I'm not questioning your knowledge of the Maxima. However, I do feel that worn/broken engine mounts can lead to transmission problems.
Here's why: If an engine mount (or mounts) is (are) broken, they place stress on other things, the engine is uneven and pulls down on the tranny, wearing away the transmission mount. A broken transmission mount leads to the tranny straining, overheating, and consequently dying.
I know this because it happened to me.
Old Jan 7, 2002 | 11:17 PM
Sudesh's Avatar
Mounts are pretty cheap. NissanParts.cc has then for around $50 each. Strauss/autozone has the same prices. Installation should be around $35 per mount.
you're better off replacing em all at once.
Old Jan 8, 2002 | 01:10 AM
Matt93SE's Avatar
STFU n00b!
Originally posted by Sudesh
Matt,
you had other problems before that, as bad engine/tranny mounts won't cause overheating.
at worst case, it will cause misalignment on the CV joints and cause the joints to wear out.
every time you hit a bump or turn the car, the CV joints move at 10x greater angles than would be caused by bad engine/tranny mounts.
when the car is at ride height, the inner CV joints are designed so that the joint will sit in the middle of the sleeve, so it's got almost 2" of travel in and out of the joint. even if the engine was turned 10degrees off-axis in the engine bay, the only thing that will happen is the joints move a bit in relation to the rest of the car.
it's a simple geometry thing.
the engine and transmissions cases are also strong enough to offset any problems with bad mounts. it can't/ won't "stress" the case on the transmission enough to cause any internal clearance issues. if they did that, then you must have actually broken the case on the transmission.
I'm not trying to argue or tell you you're dumb, but whatever caused your tranny to fail was NOT your engine/tranny mounts. There was something else involved.
Old Jan 8, 2002 | 10:20 AM
hclll's Avatar
can dirty drive belt cause engine mount going bad?
Before my max starts to have the symptons of shaking, I did belt replacing at Firestone, and they didn't put back one of the splash guard between the front right wheel and drive belt pulleys. And dirt got into the belt and pulley, caused a lot of noise.
After 1 month, my max start to shake, and with the help of several tycoons here, it is finally diagnosed as bad engine mounts.
My question is , can it be caused by dirty drive belts?
Old Jan 8, 2002 | 10:42 AM
Matt93SE's Avatar
STFU n00b!
no, impossible.
broken engine mounts are caused by hard driving, or just overall high miles and wear-and-tear.
they wear out incredibly faster when you drive hard though.
Old Jan 8, 2002 | 11:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
no, impossible.
tell me about it..
Old Jan 8, 2002 | 01:27 PM
Matt93SE's Avatar
STFU n00b!
hehehe The same goes for transmissions too, Dan.
I might have a spindle for you soon.. you wanted right or left?
Old Jan 8, 2002 | 02:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
yeah yeah..i know...flexane is filling them slowly.
err may not need it...got a alternator plug handy?
Old Jan 8, 2002 | 03:12 PM
SuDZ's Avatar
Re: can dirty drive belt cause engine mount going bad?
Trying to make Firestone pick up the bill?
SuDZ
Old Jan 8, 2002 | 06:07 PM
Thanks, I had a feeling it might be that since they didn't start doing it until about 6 months after I got them replaced.
Old Jan 8, 2002 | 06:08 PM
Thanks, I had a feeling it might be that since they didn't start doing it until about 6 months after I got them replaced. I got them replaced at this place that did nothing but cv repair service.. Figure that.
Old Apr 2, 2002 | 09:13 PM
Nismo87SE's Avatar
Re: Engine mounts lasted a week
Originally posted by 1989 4DSC
It seems like it was fine on my car for about a week then I had the same big vibration with a 5 speed starting out. The clutch and pressure plate are not that old. Do these sometime break too soon? Are there competion motor and trany mount or do I have to make my own from ? what?
Do a search for home mad urethane mounts. I garantee you'll have your answers.
Old Apr 2, 2002 | 10:39 PM
mykizism's Avatar
Matt,
I would disagree, I had broken motor mount in front, for a long time. It wouldnt pull the tranny down, or anything that terrible at all, nor would it cause overheating or making it die. After all there only so much the motor can move before it reaches' the top of the motor mount (that circle part where the bolt is bolted to) where it then stops.. but thats already high enough to hit the hood, which in my case it did.. and made a outward ding on my hood..
other than that, it will just be a very uncomfortable idle/ride, and switching between P-R-N-D
Old Apr 3, 2002 | 12:15 AM
Evil Yak's Avatar
hey, broken anything needs to be fixed
might as well fix your broken motor mount and make your car happy
i hate having broken stuff in my car.. it makes me feel poor
Old Apr 3, 2002 | 01:13 AM
Bman's Avatar
That must be my prob. I've noticed a slight squeak occasionally as I shift into 2nd now. Wasn't there a few months ago. There's actually 4 mounts right? (2 front, 2 rear) Any advice on which ones tend to go first?
Old Apr 4, 2002 | 08:37 PM
Delvin's Avatar
I bought my car back in August with both the front tranny mount and engine mount bad. I waited a little bit too long to replace them and eventually the rear engine mount went bad too. What really made the situation even worse was when my crossmember snapped in two. Thats when i replaced the three mounts (and the crossmember too) and the Max felt like a whole different car. I have a VE 5sp and i aslo noticed that my gas mileage went up too. I now have to replace the other rear tranny mount cuz its shot. I'll have fun doing that when i do my clutch next week at work on my day off. Broken mounts aren't that bad at first but can lead to a whole lot of other trouble.
Old Jul 24, 2009 | 09:39 AM
kisas's Avatar
This is a good post, I guess I need to have someone to look at the engine mounts on my car
Old Jul 24, 2009 | 02:14 PM
BenStoked's Avatar
Jesus was a Zombie.
Old Jul 24, 2009 | 09:29 PM
chrome91's Avatar
7 year old thread failboat
Old Jul 24, 2009 | 10:59 PM
colinod's Avatar
A broken mount caused a harmonic balancer to rub my brake line in half, so you're playing with your life too.
Old Jul 25, 2009 | 05:38 PM
Garf's Avatar
nobody cares.
maxinout93
Oct 27, 2015 01:29 PM
schmellyfart
Sep 25, 2015 04:47 PM
homeyclaus
Sep 3, 2015 06:15 PM
laparka66
Aug 6, 2015 09:36 AM
