Need Some help guys
Old Jan 7, 2002 | 10:23 AM
KLoWnPR109's Avatar
Need Some help guys
for those of you with systems, where did you run your power wires through the firewall? Where was there a grommet or did you just drill through the firewall, and if so, where did you drill? Thanks
Old Jan 7, 2002 | 10:33 AM
Matt93SE's Avatar
STFU n00b!
Re: Need Some help guys
topic has been discussed many times. try searching.
But to answer your question, it's best to remove the left side plastic fender liner and run it through there. you can either use the hood release cable grommet, or drill your own hole and add another grommet to the mess.
http://www.ee.utulsa.edu/~mblehm/pics/car/alarm/
look at the first few pics in there. (read descriptions also)
Old Jan 7, 2002 | 11:11 AM
KLoWnPR109's Avatar
thanks, I'll try searching next time too
Old Jan 8, 2002 | 02:02 PM
KLoWnPR109's Avatar
how would I go about removing the left plastic fender liner?
Old Jan 8, 2002 | 03:49 PM
jdmmax's Avatar
jack your car up, remove the screws along the edge of the fender.
in the back you will see some plastic plug thinys(clips) take a flat head screw driver and pop all of those things out. afte you are done getting the fender free just that the fender out and bling you will see where the wire harness in there that is going from teh engine bay to your cabin. start running wires.
oh i found this out when i was wiring my side markers. to bad caause ai already drilled into the fire wall. big No NO.
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
