5spd swap saga...
Old Aug 23, 2012 | 06:34 AM
  #41
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by mrkanda
So Dan, you've had a VG turbo with an autotragic trans this whole time, and are just now swapping to a 5spd? If so, how did it hold up this long?
i never really beat up on the auto...but it was built with high stall tc and modded vb. also had a filter and cooler with tstat on it.
i yanked it b/c the part that the dipstick bolts to the transmission cracked/broke so it was a forever leak from the transmission. tried to jb weld, tried to RTV it...nada. so i said screw it and go 5spd.
the tune is still kinda krap so i can't really beat on it anyway.
Old Aug 24, 2012 | 05:06 AM
  #42
Hectic's Avatar
sum=10
Old Aug 24, 2012 | 06:30 AM
  #43
shiloh51933's Avatar
Originally Posted by DanNY
hmmm...since i hate doing the work twice i might just go with it for a little while. i don't drive it much anyway. i also need to tune it so i'll use that time to get a semi ok tune so it'll run better.
the transmission is so light (compared to the auto) and there's sooo much room now i'm pretty sure i can drop it in a driveway and either swap the bearing or just have a shop rebuild it since god know what else might we wrong with it.
thanks gents for your help on this.
I hate doings things twice or in rare situations three times, especially something as time comsuming as swapping a/t to m/t. In this case I would have to put in that wrench time to keep my sanity. Everytime I would drive her it would fuuck with my head but that's me!! Anyway, good job swapping out that auto for the 5speed.
Old Aug 25, 2012 | 08:16 AM
  #44
All*Pro's Avatar
yup...that's the sound...mother_____....yah i'm pissed.
thanks kzoosho
Its unfortunate you had the displeasure of dealing with this scumbag who claims to be a "business man" when in reality .......he's a scumbag.
Old Aug 25, 2012 | 11:11 AM
  #45
NismoChi's Avatar
Well, if you are going to leave it like that for a while, you may as well try to put some Redline MTL or 75/90 in there to give a try. My ISB was starting to make noise, n then i did the gear oil change, after that the noise has been quiet down at least 80%.
Just my experience.
Old Aug 26, 2012 | 10:52 AM
  #46
maximo018's Avatar
Some times you got to do what you got to do to get to the end. I feel the same way but found out I wasn't able to move forward until I went back and tackled my issues.
Old Aug 26, 2012 | 05:53 PM
  #47
DanNY's Avatar
Ad·min·is·tra·tor
Just my experience.
i'm using Amsoil MTL...it's probably as good if not better than redline MTL. but it needs to be done...so i'll get it tuned right and then pull the transmission out and either rebuild or just do the ISB.
Old Aug 26, 2012 | 05:55 PM
  #48
DanNY's Avatar
Ad·min·is·tra·tor
yeah pretty much. there were soooo many parts missing. i barely got to piece it all together. i think i spent 2X what i paid for this "kit" that he advertises in buying parts that were missing or were junk.
Old Aug 26, 2012 | 05:56 PM
  #49
DanNY's Avatar
Ad·min·is·tra·tor
true...unfortunately free time is a bit scarce.
good thing i don't have to rely on the 3rd gen as a DD.
Old Aug 27, 2012 | 09:16 PM
  #50
Nealoc187's Avatar
SLOW
well... when the pedal is fully pushed in, the input shaft will be stopped. no noise due to no motion, despite supporting weight.
when the pedal is partially pushed, the input shaft will be spinning some, and the weight of the clutch disc/input shaft will be resting partly on the input shaft bearing while it's spinning, partly on the clamp load of the FW/PP. Noise due to motion and supporting weight.
When the pedal is fully out, the weight of the clutch disc is supported by clamping load of the FW/PP, and the splines of the clutch disc can support the weight of the input shaft. No noise due to not supporting any weight, despite there being motion.
Plausible?
i've never seen that happen but anything is possible i guess. i'd be interested in seeing the old bearings when he gets it taken apart.
Old Aug 29, 2012 | 08:40 PM
  #51
maxitech's Avatar
Danny,
I trust you swapped in a VLSD VE 5-speed vs an open diff 5-speed from a VG, yes?
Old Aug 29, 2012 | 09:01 PM
  #52
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by maxitech
Danny,
errr nope...used the VG open diff.
what do i need to do to switch over to the VE VLSD 5spd aside from getting the actual transmission and axles/hubs?
Old Aug 30, 2012 | 01:53 AM
  #53
MrGone's Avatar
If memory serves that's all you need.
Old Aug 30, 2012 | 01:59 AM
  #54
Greeny's Avatar
¯\(°_o)/¯
yup, trans/axles/hubs...
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
