Startup of VG rebuild
Old Aug 18, 2012 | 10:06 PM
bigmax90's Avatar
Today was the day after almost a year that I started up my rebuilt VG that I poured my blood, sweat , and tears in. Everything started up and ran fine. The only thing is that it runs really rich at idle. Trying to put the ecm in diagnosis mode cuts it off. Can this be a bad AAC valve or can it be just an injector pouring fuel at idle. When you raise the RPM's it runs fine. Its just at idle. I'm thinking an injector. Thanks in advance.
Old Aug 18, 2012 | 11:44 PM
CMax03's Avatar
Relax you'll get it.....in the meantime enjoy!
Old Aug 19, 2012 | 12:32 AM
Hectic's Avatar
Let idle for a minute, remove spark plugs, check for unburnt fuel.
Any pics of the build?
Old Aug 19, 2012 | 09:34 AM
T_Behr904's Avatar
Man i'm glad to see your car coming along. I know you can't wait to get her back on the road again! Are you trying to get her ready for the car show this coming up weekend?
Old Aug 19, 2012 | 06:03 PM
bigmax90's Avatar
And yes T..thats a fact! You know how long the whole thing has been. Trying to make it to the show and represent for our lost 3rd gens. I heard lots of the south and central fl. Will all be there to ride. The max is running rich...I m at her hard now. She sounds great though in high RPM's. Hope fully Im there next weekend.
Old Aug 20, 2012 | 04:03 PM
bigmax90's Avatar
Well guys Im still at it. Checked and rechecked for any thing unplugged or loose. No vacuum leaks or bad hoses. Fuel pressure is good according to my gauge. 38-40 @ idle. But its still running rich. Changed out the iacv and engine temp sensor. I really beleive that i have an injector just pouring fuel at idle. But when revved up to about 2500-3k it sounds great . Back at idle it bumps around. Tomoro going to pull my old fuel rail from my old motor and see if that helps, but i will first check the spray pattern of the ones in there. Im so determined on getting her right.
Old Aug 20, 2012 | 06:52 PM
T_Behr904's Avatar
Good luck man I hope you can get it figured out. It might be possible an injector might be stuck open. Have you pulled the plugs to see if any of them look rich?
Old Aug 24, 2012 | 03:51 PM
maximo018's Avatar
Read your plugs. From there figure which injector maybe your culprit. Fyi: if you made a jig for the fuel rail all hooked but out of the engine ( transparent tuba wear) you could see which one is causing you problems. Thats what I did.
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
bennuss
Sep 11, 2015 05:55 AM
