keyless entry
Old Nov 10, 2000 | 07:48 PM
hey guys/gals
mom's 93's keyless entry has been screwing up bad lately. sometimes it won't work, sometimes it will. couldn't find any info in archives or on other websites, any ideas?
thanks
Chris
Old Nov 10, 2000 | 07:53 PM
89GXE
Diag
Does she use only one door handle? The handle
may be going out. See if the problem continues if
you switch to the other handle.
Old Nov 10, 2000 | 08:49 PM
do you mean if she uses the keyless entry on the passenger side door?
Chris
Old Nov 10, 2000 | 08:59 PM
89GXE
Yes
yes
Old Nov 10, 2000 | 09:04 PM
JDwyer2821's Avatar
Re: Yes
I love the keyless entry.
Old Nov 10, 2000 | 09:09 PM
i'm pretty sure its all the keyless entry pads screwing up, but i'll ask her and find out
btw, my mom has had the "bose problem" twice, still isn't fixed. can anyone tell me (or direct me in the right direction) what causes the popping/crackling from speakers, and then the whole radio/CD/tape to die?
thanks
Chris
Old Nov 10, 2000 | 09:16 PM
JDwyer2821's Avatar
One of my bose speaker kept making that crackling noise, so I just cut the wires to it.
89GXE
Speakers
Speaker amps that's what it is, I hate the bose systems
for this reason and will ditch mine as soon as I can.
Old Nov 11, 2000 | 05:27 AM
Tick Tock's Avatar
More specific symptoms may help us provide better help to you. On mine I had one pad that would work most of the time but certain keys would not work sometimes.
Ultimately, I just replaced the whole keypad mechanism in that door handle (not too hard). I bought mine new at the time (big $$) - you should be able to find one easily at a used car yard.
Anyway, my problem was 2 of the buttons must have developed very small holes somewhere. They then got ambient air into them. So, when it was humid (or raining) they would get some moisture in them. Puzzled me because they worked most of the year, so I had ruled out moisture. What happened is moisture/humidity would get in and if it was freezing cold outside the water would freeze rendering those buttons useless. Then, when it got warmer outside or if my car was back in the garage...voila, it would work again. I spent 2 years trying to figure this one out.
Again, replacing the keypad did the trick.
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
