Servicing VG30E Valve Springs While In The Vehicle
Old Oct 4, 2012 | 11:17 PM
Porky's Avatar
Has anyone successfully disassembled their VG30E valve springs, without removing the cylinder head from the engine, and while still attached to the engine?
This would save having to touch the timing belt. I need to replace the valve stem seals, and i've heard there is some tool on the GMs that allow you to do it while in the chassis.
Old Oct 5, 2012 | 12:54 AM
Laevateinn's Avatar
make sure the valves wont fall inside the chamber. why are you gonna service the springs?
Old Oct 5, 2012 | 08:42 PM
maximo018's Avatar
I would go about it the right way instead of trying the short cut method. Too stressful and a higher risk for me.
Old Oct 6, 2012 | 08:50 AM
CMax03's Avatar
It can be done....You'll need to pressurize the cylinder with compressed air or another method is to insert a nylon rope inside the cylinder so it lays on top of the piston and when you bring this up to TDC the rope should set against the valves holding them from falling down.....just remember to leave some rope hanging out or tied to something big and don't forget to take it out b4 cranking the engine! Good luck!
Old Oct 7, 2012 | 01:54 AM
Porky's Avatar
Not worried about the valve dropping, i'm wondering how you get the springs to compress down. The springs are sort of recessed in the VG30E. Is there some tool that attaches to the rocker arm bolt holes or the rocker shaft if one removes the arms?
Old Oct 7, 2012 | 01:55 AM
Porky's Avatar
Not replacing the springs, I need to replace the valve stem seals, which merits removing the springs.
Old Oct 8, 2012 | 09:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
i thought you have to drop the valve to remove the seal...no?
Old Oct 8, 2012 | 06:01 PM
CMax03's Avatar
There's a tool for that....http://www.mandrel-bends.com/catalog...FZGiPAodpHsA5Q
Once you get the spring off you can use diagonal pliers to remove the seals
Mar 12, 2020 12:06 AM
wingnut2006
Sep 19, 2015 06:13 AM
Steven Orozco
Sep 12, 2015 10:41 PM
tardrex
Sep 11, 2015 07:35 PM
ballerchris510
Sep 10, 2015 09:35 PM
