Fuel Leak - Removing Plenum?
Old Jan 9, 2002 | 08:05 AM
finadk's Avatar
I have a fuel leak in the rubber fuel line that connects ath front and rear fuel rails on my 1990 Maxima. From what I read here this is a common problem and shows up when cold.
Is it possible to replace this line without removing the intake plenum and manifold?
If I have to remove the intake plenum and/or manifold what is involved in time and parts (gaskets etc?)
Thanks,
Scott
kneedrager@hotmail.com
Old Jan 9, 2002 | 10:54 AM
Matt93SE's Avatar
STFU n00b!
manifold must be removed.
it's take a couple of hours.
parts you'll need:
new hoses (forgot what size- call a dealer)
intake collector to throttle body gasket
throttle body to intake manifold gasket
upper and lower intake manifold gaskets.
that'll run you about $40 for the parts.
You'll also need a few metric allen wrenches to get everything off. also recommend buying a can of liquid wrench or penetrating oil of some sort if you don't already have some.
Old Jan 9, 2002 | 11:04 AM
finadk's Avatar
Thanks!
Does the manifold split with the intake plenum seperating from the manifold or does the manifole have to come off the block?
Scott
parts you'll need:
Old Jan 9, 2002 | 11:17 AM
Matt93SE's Avatar
STFU n00b!
here's some pics to answer your questions...
I left the lower manifold on the car, but you'll also have to remove it to change the fuel lines.
http://www.ee.utulsa.edu/~mblehm/pic...ntake_manifold
Old Jan 9, 2002 | 11:37 AM
finadk's Avatar
THANK YOU Mat.
A picture is definatly worth a thousand words!
Now I see exactly what I am up against. It looks pretty straight forward, as long as I have the gaskets it should be pretty easy.
Nice manifold, it came out reall good.
Scott
Old Jan 9, 2002 | 01:14 PM
Matt93SE's Avatar
STFU n00b!
yeah, it's pretty straightforward.. just getting those allen bolts loose will be a bear. I had to stick the allen wrench in the hole, then grab it with a crescent wrench and tweak on it unti lthey popped loose. the best thing to do is use the actual sockets with allen heads that you stick on your ratchet. I don't have any though, so I used what worked.
Mar 12, 2020 12:06 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
cruce91
Sep 20, 2015 10:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
