just ordered my y pipe
Old Apr 15, 2013 | 08:20 PM
mythic540's Avatar
I'm debating whether I should do it myself or take it to a shop. Is this something I can do without any crazy tools or is it strictly for the experts?
Old Apr 15, 2013 | 08:24 PM
MaximaDrvr's Avatar
It is fairly easy to do yourself. The bolts may be very tight though. I recommend soaking them with penetrating oil overnight before attempting.
Old Apr 16, 2013 | 12:19 AM
mythic540's Avatar
Anyone have a good write up or link on a how to do it?
Old Apr 16, 2013 | 07:19 AM
shiloh51933's Avatar
When u get the pipe you'll see that it's self explanatory...the flange bolts will more than likely be frozen. Have some PB blaster at hand and a blow torch to heat up the bolts for removal. You can do this yourself brother...just need some hand tools, ramps or jack stands, PB blaster and maybe a 14 ounce propane bottle torch.
Old Apr 16, 2013 | 08:20 AM
mythic540's Avatar
OK, thanks for the encouragement!
Old Apr 16, 2013 | 09:56 AM
CMax03's Avatar
Save your money DIY!
Old Apr 21, 2013 | 01:37 PM
93maximaguy's Avatar
DIY for sure. When I did mine it took me maybe an hour and a half (fighting frozen bolts by hand). super easy when you are actually swapping it though.
Old Apr 21, 2013 | 02:13 PM
Zach-R's Avatar
DIY and spend the money you save on more parts! When you get the bolts out its not a bad idea to replace them and cover the new ones in anti seize to prevent them from seizing up again. Good luck.
Old Apr 21, 2013 | 05:02 PM
coolsun's Avatar
When i did mine, nyc weather made the part where it connects to the main cat impossible to take off. So i cut it off, but i also had a new cat to install at the same time, so it wasnt an issue. good luck, remember use good jack stands!
Old Apr 29, 2013 | 04:52 PM
MaximaDrvr's Avatar
I did mine on ramps, in the snow. Talk about frozen bolts....
Took about an hour. The car had 110k miles at that point.
Old May 1, 2013 | 11:06 PM
mythic540's Avatar
Got it in!! I noticed it didn't come with any gaskets, I'm assuming I have to buy them myself?
Old May 4, 2013 | 06:52 PM
mythic540's Avatar
I'm confused on what I need to buy to install, it came with these metal rings and a bracket and what appears to be a gasket for the part that attaches to the cat. Anyone have a write up for installing this y pipe?
Old May 4, 2013 | 07:07 PM
Levsimus's Avatar
If I'm on the same page, the metal rings are the gaskets. Unbolt the old pipe, remove the old gaskets and replace with new and pop her on!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
bigfrank
Oct 1, 2015 12:51 PM
