sad day cuz my frontr lip crack in half. help
Old May 10, 2013 | 01:51 PM
TonyJr's Avatar
well i found a stillen front lip that im picking up in 2 weeks locally. but my ? is does bigger rims increase my car heights because its toooooooooooooo low with the lip right now?
im thinking about getting 17'' rims. and i think my intrax springs are 1.75 drop. what a good tires size and rim size to increase height without removing the springs?
Old May 10, 2013 | 02:11 PM
The Maxima's Avatar
Yes rim size increases your cars height.
Old May 10, 2013 | 02:27 PM
nismo_max's Avatar
No, rim size does not increase or decrease you cars right hide. if you have a 16" wheel with regular profile stock tires, and you are wanting to get 18" wheels, with low profile tires, it could be the same as your 16's. tire profile changes the ride height of you car, not nessesarily the rims size
Old May 10, 2013 | 02:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
as long as the diameter is the same as stock...the height will not change.
Old May 10, 2013 | 03:19 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Then explain this.
15 inches
20 inches (rear) and 19 inches (front)
Old May 10, 2013 | 04:40 PM
TonyJr's Avatar
Then explain this.
15 inches
Lmao. I guess I'll get 17" with 215/55/17
I have right now 215/55/16. Would this make a little difference
Old May 10, 2013 | 06:07 PM
those numbers WOULD cause an increase.... because you changed the rim size without changing anything else.
Stock tire height is 25.5"
Your current is 25.3"
The 215/55/17 would be 26.3".
With that size you're going to want to make sure you aren't too close to the strut towers, or else you risk your tire binding against the lower spring seat. If you get the maxima wheels that I used to have, you might need spacers since the spring perches are sightly angled, so the further away you are from them the more room you have for a tall tire.
Old May 10, 2013 | 06:23 PM
TonyJr's Avatar
What kind of spacers I should get and where can I find them for a good price ?
Old May 10, 2013 | 06:53 PM
This is what i mean by the underside of the perches are angled, because the whole thing is angled (kingpin inclination). This pic is a z31 front strut but it's very similar to a Maxima rear strut.
Old May 10, 2013 | 06:58 PM
wheel spacers with a 5x114.3 bolt pattern If you get the 5.5gen SE wheels you should be able to do a 15mm spacer which is thick enough to use studded spacers. Go hub-centric if possible.. i forget what our center bore is, but it will be the same for all 5-lug maximas.
This is a 15mm studded hub-centric spacer. Note the stock studs poking thru, and note the hub-centric lip in the middle that will align the wheel.
If you decide to run oversize tires, see if the wheels will fit without spacers, and if they won't, see if you can figure out how far away you are by adding some 12mm washers until they do fit.... with the car in the air, NOT on its own weight.
What fits in the air should fit on the ground b/c the wheels and struts move together as an assembly so the clearance between them should be fixed.
Old May 10, 2013 | 09:16 PM
James92SE's Avatar
2 VE's are better than one!
Wasn't your lip fiberglass? That's why it cracked.
Urethane (Stillen) is where it's at. 10+ years here on my Stillen
Either way, your front end can only get damaged if you, well, run it into things. You can't be lowered and be one of those people who pulls up into parking spots until your tires hit the curb. You have to permanently change the way you drive.
Old May 11, 2013 | 12:35 AM
Hectic's Avatar
Buys body kit, paints car, lowers car, cracks front lip in half.
Ricer's law.
Old May 11, 2013 | 04:31 AM
TonyJr's Avatar
Ricer's law.
Are you serious by calling me out as a ricer, you don't even know me. Never will be one so step off.
Anyways I'm picking up my stillen front lip for $60 in 2 weeks. Got to get use to driving low but I learn my lesson. And as for the fiberglass kit I bought it for $70 on Craiglist. I still have it n I believe I can repair. Either way I'm still going to put on the stillen front lip.
Old May 13, 2013 | 05:33 PM
Hectic's Avatar
No not calling you a ricer, just stating the law. For example someone removes rev limiter, puts car on the dyno and blows up their engine. I'll be the first to admit that if my car had a body kit on it, i'd probably damage it within a week.
Old May 13, 2013 | 06:02 PM
TonyJr's Avatar
my bad i though wrong. but i hate the ricer style.
Old May 13, 2013 | 06:17 PM
DanNY's Avatar
Ad·min·is·tra·tor
i'm rocking the ricer style...what's wrong with that??
Old May 13, 2013 | 07:44 PM
TonyJr's Avatar
just not my style. just go with what floats your boat.
Mar 12, 2020 12:06 AM
maxima-junky
Nov 10, 2015 09:12 AM
wingnut2006
Sep 19, 2015 06:13 AM
