Desperately need help removing rear seat off a '89 GXE
Old Jan 13, 2002 | 09:11 PM
monkeyboy's Avatar
I found instructions, I've searched the forums, and I can't figure this out. Everything I have read says to just pull up, and the bottom part will come out. There is supposed to be two pins that you pop out by pulling.
I have had two people both pulling on one side, and nothing. No matter how much pressure we apply, the thing will not come up. Does anyone know if '89 rear seats are different than 90+ seats?
Any help would be GREATLY appreciated.
Old Jan 13, 2002 | 09:18 PM
«§»Craig B«§»'s Avatar
Re: Desperately need help removing rear seat off a '89 GXE
I removed the seats in my 89gxe the exact same way as my 93SE. There is no difference. I'm assuming you've already seen teh instructions on my webpage
there are two clips like you mentioned, the first few times, they are a real pain to pull up
you should be able to reach your hands under the seat and feel where each one is (one basically under the middle of each outside seat). Then put one hand on each side of teh tab and pull up as hard as you can. I usually get in the car completely and face the rear windshield. And then when it finally comes out, you hit your head on the ceiling
good luck and just keep trying
Old Jan 13, 2002 | 09:35 PM
mateo92GXE's Avatar
I know your dilema, the rear seats are hard as hell to get up. Try and get a really strong piece of medal, and put it between the seat and the frame and pry it. They are super hard and havent come out in probaly 13 years. I bent a screw driver doing this, so try and get something like a crow bar!!!
Old Jan 13, 2002 | 10:21 PM
monkeyboy's Avatar
Thanks guys. I finally got it.
I broke one of the plastic inserts in the process, but at least I got it up. The plastic insert came up with the pin. It is still stuck in there. The facing forward/bump you head position was what finally gave me enough leverage.
Holy crap that was hard to get up. Thanks again.
Old Jan 13, 2002 | 10:57 PM
Lordrandall's Avatar
Re: Re: Desperately need help removing rear seat off a '89 GXE
I knew there was a reason I left that lower cusion in when we did the spring/strut job.....
raywluce
Mar 10, 2025 09:34 AM
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
