Rebuilt motor
Wow, does anyone even make a rebuild kit anymore for these cars?
I'd go oem, try www.nissanpartsasap.com and call them, speak to Ray or "Big" Wayne.
Might also try Rockauto. They should at least have most the gaskets you need.
Even when I bought the Nissan oem rebuild kit for my VG, it did not come with anything but gaskets and a few other odds and ends like rings and valve seals..... no sensors, no pistons.
I had so much left over from my rebuild kit, I imagine it was NOT worth the cost. But, you might look at adding the stuff up you need seperately and see which is the better cost. It would had been cheaper for my to just buy the gaskets and stuff I needed. For example, my block ended up being bored, so I had to buy oversized rings for my new pistons. Ended up speding more having purchased the kit. Of course, I bought the kit BEFORE all that work had been done.
if anything i would see if you can get forged pistons and just rebuild the whole engine i cant see how doing the valve cover gaskets etc is gonna help anything that much unless theyre already bad
List
Lifters
Intake valves
Valve cover gasket
Valve seals
Valve stem seals
New head bolts
Cam seals
Exhaust manifold gasket
What's parts usually are reused?
My friend told me I should balance the cylinder head that sit on the block cause its not going to sit right if I don't do it. Is this true?
Lifters
Intake valves
Valve cover gasket
Valve seals
Valve stem seals
New head bolts
Cam seals
No, you really only need to do that if the head gasket has blown. But, it's not a bad idea to have the shop inspect it. I assume you're going to have a shop do the work unless you have the tools to pull valve springs (Wayne can attest to those dangers! LOL!!) and do it safely? The shop can tear it down, ensure the heads aren't warped, clean it, reinstall all your new parts and the cams with seals.
You might even talk to them to see if they can enlarge the valve openings a bit and port match. I think you would be pleased with the results.
AaronL
08-08-2020 10:31 AM
04-16-2020 05:15 AM
Unclejunebug
04-02-2016 05:42 AM
knight_yyz
11-01-2015 01:34 PM
