Anyone ever replaced a Speedo Sensor before?
Old Jan 15, 2002 | 01:51 PM
Turbo Todd
I was wondering how hard it was to do and where to get one for a decent price. I called local wrecking yards and they are not available from them. Bet price I have found so far is $75.00 new.
Any ideas?
Todd
Old Jan 15, 2002 | 02:16 PM
Matt93SE's Avatar
STFU n00b!
welcome.. try the search function on "speed sensor"
It's a common problem on maximas. 10 minute job to replace, about $60.
Old Jan 15, 2002 | 02:49 PM
mykizism's Avatar
hay matt while we are on the subject.. i have VE face gauges.. im wondering if the VE speed sensor would work with my auto vg ??
Old Jan 15, 2002 | 02:53 PM
davis4004's Avatar
Sounds like a reasonable price, but try for $60.00 like Matt said, call up Courtesy Nissan www.courtesynissan.com and ask them for the price. Tell them that your a maxima.org member and they should give you a 25% discount, if you can wait it is ten times better to order it from them. On the VG auto it is located at the back and has one bolt holding it in, you just take the bolt out wiggle it around a little, and it should pull right out.
Old Jan 15, 2002 | 02:58 PM
Turbo Todd
cool! thanks for the guidance guys!!!!
Old Jan 18, 2002 | 01:36 PM
AUSTIN618's Avatar
Re: Anyone ever replaced a Speedo Sensor before?
Any ideas?
Todd
Before you buy a new sensor, try this first, if you haven't already done so.
1. Pull out the top part of the sensor from the metal housing (you don't have to remove any bolt).
2. Turn it over and look inside, you should see multiple metal pieces on
the inside wall. If they are covered with black stuffs, get some fine sand paper (360 grit or greater) and gently clean it.
3. Put it back and test drive the car and see if your speedo is working now.
My speedometer was dead for over a year, I did the above steps and it worked. Good Luck!!!
Old Jan 18, 2002 | 01:40 PM
Turbo Todd
I have not done anything with it yet. I will give that a try before I go an buy the part.
BTW, Courtesy Nissan priced that to me at $125.00 with the Maxima.org discount. OUCH!!!!!
mrc00l88
Jan 25, 2024 01:14 PM
AnsonJ
Jun 2, 2017 01:35 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
