Help!, Window switch does not work
Old Jan 15, 2002 | 05:40 PM
elvatoli
My Driver side window switch stops working on controling the drivers side window. If I roll down the window it do not operate to roll up that window.
The other windows are working OK. I'm already changed the motor and the window mechanism for 3 doors, but now the problem is on the switch.
Can I repair this kind of problem?, Or there is no other way than buy a new switch control panel for the drivers side (main). Is very expensive because Nissan sell it for $180 dlls. Or maybe there is a place to buy it a lot cheaper.
If I replace this control panel, somebody knows if it will operate the automatic unlock for all doors with the key?, Because this function is not working for 2 years ago.
I will apreciate your help or recomendations.
Old Jan 16, 2002 | 04:28 AM
ninezero's Avatar
Re: Help!, Window switch does not work
big change your masterswitch has a defect and there is almost no
way too repair it, if you dismantle it and there is nothing wrong
with the connectors or any soldering.
try car-part.com for a used one for 35-45 $
Btheman80
May 1, 2018 04:03 PM
vingodine
45
May 21, 2016 12:46 PM
mpbclutch33
Aug 21, 2015 06:09 AM
KGMtech
Aug 18, 2015 09:21 AM
kjm900r
Aug 5, 2015 07:14 AM
