intercooler
Old Aug 14, 2013 | 08:52 AM
90grey-vg's Avatar
intercooler
So I'm going to turbo my max and I've always wondered, what would be better if I was running only like 7psi. A front mount intercooler. Or none at all. I know its always best to try to keep everything as cool as I can,but I was also thinking,wouldn't there be a better throttle response if I didn't use one, due to the fact that its a shorter path for the air to travel...?
Old Aug 14, 2013 | 02:05 PM
DanNY's Avatar
Ad·min·is·tra·tor
- what's your REALISTIC power level you're looking to achieve?
- what turbo are you using?
- what's your turbo map and what CFM do you intend on flowing? specs of hot side and cold side A/R?
- what size injectors are you looking to use and run?
- stock FPR?
- what motor are you looking to use?
- stock cam? aftermarket cam?
- automatic or manual trans?
- modifying the intake manifold or leaving it stock?
Old Aug 14, 2013 | 06:29 PM
chrome91's Avatar
just use a intercooler, i know Z31 turbo didnt have intercooler factory but its a good idea to have one
Old Aug 14, 2013 | 06:36 PM
90grey-vg's Avatar
I'm using stock everything, I'm gonna find a t25 or a t28 from the junkyard off a saab or volvo. I won't have it turned up past what they are originally for simple fact that I don't feel like going all out on a build. Eventually I'll pull the motor and do a complete rebuild that way I can safely rum high boost. This is just something to give me a nice little kick for now.
Old Aug 15, 2013 | 06:39 AM
DanNY's Avatar
Ad·min·is·tra·tor
then don't bother with the IC
Old Aug 15, 2013 | 04:50 PM
akurtzer57's Avatar
don't bother with t25 or t28 find atleast a t3 off a z31.
Old Aug 18, 2013 | 12:21 PM
Chris Gregg's Avatar
Get Off My Lawn
T3 minimal. You can get a new core and use the old housings from the z31. Save some money that way and have essentially a new unit. If you are running less than 10 psi, then no intercooler is needed.
Old Aug 18, 2013 | 11:54 PM
Hectic's Avatar
- stock FPR?
And the interrogation begins
Old Aug 20, 2013 | 09:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
those are legit questions. if you don't have a game plan or a goal then it's going to be a hot mess. knowing what you want to get and setting a realistic budget is the key to all this.
Old Aug 20, 2013 | 05:57 PM
chrome91's Avatar
its because half the people that want to turbo their 3rd gen wouldnt even know where to start, thinking its straight bolt on parts and 2 hours of work
Old Aug 21, 2013 | 07:22 AM
shiloh51933's Avatar
Another dreamer with big plans...start a thread when you have all the parts in ur garage ready to go!!
Old Aug 21, 2013 | 08:39 PM
akurtzer57's Avatar
Where I was at one time. Why I try be honest straight up with minimal criticism as possible.
A lot of the seniors around here gave me same treatment years ago. Never know one might come through like I did.
Old Aug 21, 2013 | 11:30 PM
Hectic's Avatar
Didn't you just blow up your engine?
Old Aug 22, 2013 | 05:31 AM
Nice!!
Old Aug 22, 2013 | 05:56 AM
Max_Gator's Avatar
And so what if he did . . . He simply made a suggestion for a turbo.
You think that nobody else has broken???
Old Aug 22, 2013 | 08:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
i assume at some point you had a plan right?
you know what you wanted to do. amount of boost you wanted to build. the turbo you plan on using..etc etc??
Old Aug 22, 2013 | 09:11 PM
Hectic's Avatar
These guys know I'm just joking around. Of course you fart around in the 5th gen section and wouldn't know that.
Old Aug 25, 2013 | 07:11 AM
akurtzer57's Avatar
Ya I did. Pushed the stock motor on pump gas. How many other maximas have ran 25psi stock internal motor? Ran it for long time. Would still be going if had it on e85 or meth injection.
Old Aug 28, 2013 | 06:04 AM
You had a VG block or VE...i'd guess VG would have a better chance holding up that long with 25psi of boost but the VE was no slouch?
t6378tp
Sep 29, 2018 04:27 PM
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
