Where to find ECU-1991 Maxima
Old Oct 11, 2013 | 04:19 PM
brycea's Avatar
I understand that the ECU is on the passenger side, below the dash. Does this mean where the flat part of the floor board, begins its angle upward, that being, the ECU is located on the angled area.
Old Oct 11, 2013 | 05:33 PM
Hectic's Avatar
It's right behind the center kick panels. Basically under your stereo, but further forward. You get the picture. Take the kick panels off and it's right there.
Old Oct 11, 2013 | 05:47 PM
brycea's Avatar
Okay, I understand under the stereo, but
You say remove the kick panels, I'm not too sure what you mean. If I understand you correctly, the ECU is under the stereo. If I were to do a diagnostic test, where should I access the unit. Thanks for your help.
Old Oct 11, 2013 | 05:53 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/3rd-generat...-then-off.html
Old Oct 12, 2013 | 07:38 AM
shiloh51933's Avatar
If you must access the ECM/ECU the access panels aka kick plates are under the dash behind stereo/climate control by the center drivetrain hump. There's one on each side L/F(by gas pedal), R/F(by left foot).
Old Oct 12, 2013 | 07:52 AM
brycea's Avatar
Hey Thanks!
Would you know what side I will access in order to see the diagnostic lights.
Old Oct 12, 2013 | 08:53 AM
Passenger side(R/F).
ah2002
Mar 9, 2016 01:42 PM
Wolvee
Aug 11, 2015 12:24 PM
MikesChevelle
Aug 7, 2015 05:57 PM
BassAddictJ
Aug 4, 2015 11:38 AM
