under drive pully
Old Jan 23, 2014 | 12:38 PM
ac max 92's Avatar
under drive pully
Anyone know who has under drive pullies available for the 3rd Gen gxe's? I know they were available for the 3rd Gen se's but I haven't been able to find any available for the gxe??
Old Jan 24, 2014 | 05:39 PM
DanNY's Avatar
Ad·min·is·tra·tor
i think i have a UR...not sure if they make them anymore.
Old Jan 24, 2014 | 06:38 PM
ac max 92's Avatar
I believe you may be right. I've had no luck finding one yet anyway. I think unorthodox makes or made one for the se but not the gxe. I saw a senior in his late 70's with a 3rd gen that looked like it had just rolled off the lot it was in such good shape and was a gxe and he had an underdrive pully but it was years ago and i didn't think to ask where he got it. Is your pully for sale or is it in use? and is it for the gxe?
Old Jan 25, 2014 | 07:55 AM
DanNY's Avatar
Ad·min·is·tra·tor
it's in use...but i've been looking for a stock one to replace it (one that's doesn't wobble).
it's for a VG30E motor...so it should fit a GXE.
Old Jan 27, 2014 | 07:41 AM
CMax03's Avatar
ASP racing and I have an OEM sized billet Aluminum for sale (light as Hell) and still keeps your voltage up on your battery!
Old Jan 29, 2014 | 09:54 AM
Chris Gregg's Avatar
Get Off My Lawn
Originally Posted by CMax03
...... and still keeps your voltage up on your battery!
Very important. The old 2nd and 3rd gen Maxima's are known for charging problems even in stock form. There was a recall back in the day where they actually brought cars in and swapped out the pulley on the alternator for one to speed it up. You do NOT want to underdrive the systems on the VG.
If you're looking to lighten things up, a Fidnaze aluminum flywheel definately helps out. Anticipate losing some torque. But, if you do the cams and headwork like you seem to be considering, you'll more than make up for it in power gains.
Old Jan 29, 2014 | 10:18 AM
DanNY's Avatar
Ad·min·is·tra·tor
i don't have a voltage problem with the UR...hmmm....
Old Jan 29, 2014 | 11:27 AM
Get Off My Lawn
I'm certain about the recall (or TSB), I had the paperwork at one point. I know some people did not have issues underdriving. My guess is Nissan resolved the issue with enlarging the pulley on the alternator. I'm trying to recall if there was some findings that certain underdrive pulleys were a bit smaller and that was causing charging issues. Clearly, you've had no issues.
OP, just something to check after installing an underdrive pulley...ensure you've still got 14.4v.
Old Jan 30, 2014 | 07:07 AM
CMax03's Avatar
You mean decreasing the diameter of the altenator pulley....I'm running a UR and It's had no issues with the charging system! But I did have both underdrive and OEM sized ASP racing pulley made and I have 1 left!
Old Jan 30, 2014 | 12:47 PM
Get Off My Lawn
Yes, decreasing. Correction noted, thank you.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Pixel
Sep 15, 2015 05:53 AM
Maxie40
Sep 14, 2015 11:28 AM
