found transmission leak help
i found a leak at the output shaft seal. smh
i notice that the gears were hard to go in so i check the oil level and it was low. so i added more tranny oil but now my 5th gear wont work at all and 3rd gear goes in rough. did i wait to long to add more oil? planning to replace the seal tommorrow and drain all the oil and add new oil again. is there anything i can do to help with the 5th gear issue and 3rd gear?
dang, be clear :P
if it's the axle seal, why would folks still say be needs a trans rebuilt??... no it doesn't. it's cake to replace the driver side axle seal!! You also say you hear grinding on the driver side... u have a bad axle CV joint.
replace the driver axle & seal! done
Axle is new smh.
Yes I know the seal is leaking. Yes it's easy to replace. But transmission still need a rebuild either way. It's working but I'm tried of the synchroniz noise. Wait wait wait I know bro lol
WAIT WAIT WAIT! is it the dang axle seal or the trans output shaft seal(this seal has the shaft that enters into the torque converter or clutch works)
dang, be clear :P
dang, be clear :P
- Yes it's axle seal
- No trans does not require a rebuild to change it
sctludwig
Sep 1, 2022 01:32 PM
