Tranny oil addatives*
Old Jan 23, 2002 | 09:50 PM
ChrisCheezer's Avatar
has any one ever used any tranny tretment, if so have you felt improvment?
i have an auto... whats the best tranny fluid i can use?
Old Jan 24, 2002 | 05:03 AM
nubiannupe's Avatar
OG Maxima.org Member
Funny you mentioned that, because I'm sitting here with a bottle of DuraLube auto tranny treatment in front of me. Contemplating on just WHEN to use it.
Old Jan 24, 2002 | 06:45 AM
brubenstein's Avatar
I recently started using Lubegard (http://www.bulkparts.com/MM007.ASP?pageno=174) in the red bottle. Good stuff. Makes shifting quicker and smoother. It takes about 25 miles of driving for it to do its thing.
Old Jan 24, 2002 | 09:11 AM
dnas420's Avatar
i use valvoline maxlife on oil and tranny i posted about this last week.
here is the post: http://forums.maxima.org/showthread.php?threadid=91063
Old Jan 24, 2002 | 08:08 PM
superdesi's Avatar
Did the mystery oil (MMO) ever work for you?
Old Jan 24, 2002 | 08:49 PM
dnas420's Avatar
yes it did
i had a good experience with the product. it has worn off a bit, i only used it once. but i might try this valvoline first. oil is great.
Old Jan 25, 2002 | 10:50 AM
The MMO made the shifts quicker and firmer (some varnish cleaned off the selenoids?). Remember though. MMO should be used in a transmission as a mild flushing agent, and not a long term additive. About 4 days after I put the MMO in I did a complete fluid exchange and switched to synthetic ATF. Lubegard is an additive put in after a change that stays in until the next scheduled fluid change.
Old Jan 25, 2002 | 11:50 AM
superdesi's Avatar
Of the 10 oz. bottle, how much exactly did you add?
Did you do another drain and refill before you added this?
Old Jan 25, 2002 | 04:49 PM
davis4004's Avatar
Whatever you do DO NOT use Slick 50 high mileage treatment or any other thick additive. I put Slick 50 in mine to help it last longer since it was starting to slip and I think it caused my transmission to finally die within a month.
Old Jan 25, 2002 | 05:02 PM
superdesi's Avatar
I have used Slick 50 in the past and had no problems. I also added Z-max trans formula and had no problems. I do believe in MMO however, due to the many positive responses from hundreds of real people testimonials.
I think all additives are "snake oils" including LubeGard.
I think from now on I'll just stick with regular good 'ol ATF!
Old Jan 25, 2002 | 05:47 PM
I'm using the Lubegard in a Mystique trans that holds 10qts, so 10 ozs the the perfect amount (1 oz per qt of fluid). I would just use the whole bottle in the Max trans.
I generally don't use oil additives (engine/trans). The only I even tried the Lubegard is because it is highly recommended by a pertroleum engineer on the Yahoo, Infiniti board (and he's even older than me). Most of the stuff out there is junk, but there are a few good products.
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
